High voltage motor phase failure protection circuit
Source: InternetPublisher:elleny Keywords: Protection circuit piezoelectric motor high voltage Updated: 2020/10/16
For a high-voltage motor controlled by a vacuum circuit breaker , if
the vacuum circuit breaker is improperly adjusted, it can easily cause the motor
to run out of phase. If not discovered in time, it may cause the motor to burn
out. Therefore, it is necessary to install a high-voltage motor phase failure protection device.
The circuit is shown in Figure 4-56. In the figure, KAi and KAz are overcurrent
or current quick-break protection relays; KA3, KA4, and
KA5 are overcurrent relays for phase failure protection; KS is a signal
relay; KT is a time relay; and KC is an intermediate relay
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Build a glove-controlled robotic arm
- Manual automatic air compressor control circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Delay switch made with LM431
- Ultra-short wave item left behind reminder alarm
- Bicycle anti-theft alarm
- Transistor leakage release protection circuit
- Low voltage blocking overcurrent protection circuit
- Overload protection circuit for high-voltage motors
- Thyristor silicon stack protection circuitb
- Thyristor resistance-capacitance protection circuit a
- Star connection motor phase failure protection circuit
- Thyristor type overcurrent protection circuit 3
- Mains undervoltage and overvoltage protection circuit three
- One of the mains undervoltage and overvoltage protection circuits
- Three-phase AC power supply phase sequence protection circuit
