High-voltage motor one-phase overload protection circuit a
Source: InternetPublisher:方世玉223 Keywords: Protection circuit piezoelectric motor high voltage Updated: 2021/09/22
The so-called high-voltage motor generally refers to a motor with a rated voltage of i~iokV , and the capacity is generally above 150kW
. In order to ensure safe operation, relay protection devices need to be used for protection. The one-phase, one-relay overload protection circuit for
high-voltage motors is shown in Figure 4-49.
In the figure, TA is the current transformer. KA is the overcurrent relay, KS is the signal relay, QF is the circuit breaker, and
YR is the circuit breaker tripping coil.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- How to choose the right level of integration to meet motor design requirements?
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- How to remotely control devices using ESP8266 and LPC2148
- DIY an electromagnetic levitation device
- Light-controlled circuit design and analysis
- Design and production of no-load automatic power-off device for household power supply
- PIC microcontroller controlled remote anti-theft alarm circuit
- Home wireless burglar alarm circuit
- Water supply reminder after water outage
- Delta connection motor phase failure protection circuit
- Water inlet motor protection circuit
- Voltage type leakage protection circuit
- Repeated ground protection circuit
- Structure and working principle diagram of various protection circuitsg
- One of the regulated power supply overcurrent protection circuits
- One of the series-type regulated power supply circuit protection circuits
- Thyristor type overcurrent protection circuit 3
- Mains undervoltage and overvoltage protection circuit three
- Overcurrent protection circuit for generator low voltage start b
