Current transformer multi-function protection circuit a
Source: InternetPublisher:风向西瓜 Keywords: Protection circuit current transformer BSP relay Updated: 2021/03/30
The current transformer can be used to reflect the magnitude of the stator winding current. When the stator winding current exceeds the allowable value (avoiding startup
and current fluctuation time), the current signal detected by the current transformer acts on the relay through the electronic circuit , causing the contactor
to trip. , cut off the motor power. The multi-functional protection circuit
of current transformer is shown in Figure 4-41. This circuit has overload protection, rapid braking, phase failure protection
and alarm functions. Thermal relay FR serves as overload backup protection and phase failure protection.
When adjusting, connect the rated load and adjust the potentiometer RP so that the secondary voltage of TA is 1~2V (if it cannot be reached,
the number of primary turns can be increased), that is, the base voltage of the transistor VTi is o. 2~0.4V, in a reliable cut-off state; when the motor is overloaded
, it can ensure reliable conduction of VTi and the relay KA is closed.
- Peripheral circuit of automotive motor controller power supply chip
- Perform surgery on the speaker protection circuit
- A small improvement on the ordinary refrigerator motor starting circuit
- A small improvement to the temperature and water level indicator alarm
- Motor control circuit for starting and running without phase loss
- Simple phase failure protection circuit composed of intermediate relay
- Add one more component to improve the phase failure protection function
- Design and analysis of the principle of automatic power-off switch during power outage
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Delay switch made with LM431
- Voice controlled flash LED light circuit diagram
- Electronic thermometer circuit
- Egg warming circuit
- Peanut and melon seeds roasting machine circuit
- Junction field effect transistor mixer circuit
- Series crystal oscillator
- Voltage-controlled voltage source second-order active low-pass filter circuit
- color discrimination circuit
- Color display circuit
- Various signal generator circuits
