Harmonic current phase failure protection circuit one b
Source: InternetPublisher:qoistoochee128 Keywords: Protection circuit harmonic current phase failure protection BSP Updated: 2020/12/29
Harmonic current phase failure protection uses the detection of the third harmonic current in the secondary winding of the current transformer to achieve phase failure protection
. Because the third harmonic is in the same phase and is equivalent to a zero-sequence system, harmonic current protection is also called zero-sequence current protection.
The third harmonic current is used to reflect the operating status of the motor. The current transformer used is not a linear current transformer, but
a fast saturation current transformer.
The circuit is shown in Figure 4-25. When normal, relay KA is closed; when the power supply phase is missing, KA is released and the motor stops.
In Figure 4-25 (a), KA makes and breaks the main contact (3A), so it is only suitable for no-load starting of motors below 1.lkW.
- A simple magnetic switch circuit sharing
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- A simple door handle touch alarm circuit
- What is a RADAX motor?
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Simple three-phase motor phase loss protection circuit
- Audio interface protection circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- Night dog barking anti-theft reminder circuit
- Set timing circuit when power is on
- Analysis of rectifier circuit types and principles
- Electronic thermometer circuit
- Proportional frequency discriminator circuit
- base amplitude modulation circuit
- Inductive feedback oscillator circuit
- Capacitive feedback oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- OTL low frequency power amplifier circuit
- Small current generator circuit
