Harmonic current phase failure protection circuit one a
Source: InternetPublisher:清宁时光 Keywords: Protection circuit harmonic current phase failure protection BSP Updated: 2020/11/22
Harmonic current phase failure protection uses the detection of the third harmonic current in the secondary winding of the current transformer to achieve phase failure protection
. Because the third harmonic is in the same phase and is equivalent to a zero-sequence system, harmonic current protection is also called zero-sequence current protection.
The third harmonic current is used to reflect the operating status of the motor. The current transformer used is not a linear current transformer, but
a fast saturation current transformer.
The circuit is shown in Figure 4-25. When normal, relay KA is closed; when the power supply phase is missing, KA is released and the motor stops.
In Figure 4-25 (a), KA makes and breaks the main contact (3A), so it is only suitable for no-load starting of motors below 1.lkW.
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- How to set up a cheap beam break sensor control distance scene using a reflector
- Working principle of one Xipu STR soft starter controlling two motors
- Squirrel cage asynchronous motor reverse braking control circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Methods for Eliminating Noise of Brushed DC Motors
- Audio interface protection circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- Infrared detection alarm
- Set timing circuit when power is on
- Analysis of rectifier circuit types and principles
- Electronic thermometer circuit
- Proportional frequency discriminator circuit
- base amplitude modulation circuit
- Inductive feedback oscillator circuit
- Capacitive feedback oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- OTL low frequency power amplifier circuit
- Small current generator circuit
