Simple LED reading lamp
Source: InternetPublisher:通通 Keywords: LED Circuit Updated: 2024/08/26
This desk lamp can emit cold light suitable for reading. 50 white LEDs (LED1 to LED50) are arranged in an array to emit white light to cover the table.
As shown in the figure, 50 white LEDs are arranged in a 10×5 array, and then powered by a 220V AC power supply. The AC power supply is rectified by a bridge D1-D4, and a transistor T1 and a field effect transistor T2 are used to maintain a constant low voltage of the LED array. This allows the brightness of the desk lamp to remain stable even when the input power supply voltage changes.
The bridge rectifier converts the AC voltage into a pulsating DC voltage. When the voltage at the capacitor C1 exceeds 40V during each pulsation cycle, transistor T1 drives field effect transistor T2 into the non-conducting region to maintain a constant low voltage across the LED array. Resistors R5-R9 (220Ω each) are connected in series to their respective LED branches to limit the current flowing through the LED to a safe value.
During installation, 50 LEDs are arranged into a circular array on a PCB board, and the PCB board is mounted on the top of the desk lamp, and a circular reflector is added to increase the illumination.
Note: Since the circuit is not insulated from the AC power supply, do not touch any part of the circuit to avoid fatal electric shock.
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What is the difference between CPLD and FPGA?
- Transfer characteristics of BJT, how to apply Shockley equation?
- Datasheet/Pinout/Technical Specifications of LMC555
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Share a Motorola amplifier circuit
- Ceramic filter structure/working principle/characteristics/application
- Build a musical fountain using Arduino and sound sensor
- Simple LED advertising light circuit
- simple photometer
- Photoelectric conversion and voltage-to-current conversion circuit diagram
- Capacitor step-down LED drive circuit diagram using varistor
- Capacitor step-down LED drive circuit diagram using thyristor
- Energy-saving household small neon light circuit production
- Typical circuit diagram of LED indicator integrated circuit
- Novel solar LED light controller circuit diagram
- LED lighting circuit diagram in refrigerator
- MIC2298 driving LED circuit diagram
- MAX1913 driving white LED circuit diagram
