The autotransformer steps down the voltage and the rotor is added to the excitation starting circuit according to the frequency change.
Source: InternetPublisher:宋元浩 Keywords: Excitation autotransformer starting circuit frequency change Updated: 2021/09/19
The circuit is shown in Figure 3-187. When starting, connect the autotransformer ZQB to reduce the voltage and start. After a period of delay,
ZQB exits operation and the motor speeds up under full pressure. When the speed rises to the quasi-synchronous speed and above, cut off (short-circuit) the discharge resistor R:, add DC excitation
to the rotor winding , the synchronous motor is led to run synchronously, and the starting process ends.
- DIY a simple fire alarm
- Model rocket launch controller circuit
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- A small improvement on the ordinary refrigerator motor starting circuit
- Motor automatic cycle control circuit
- Simple phase failure protection circuit composed of intermediate relay
- Design and analysis of the principle of automatic power-off switch during power outage
- Temperature control circuit design and analysis
- PIC microcontroller controlled remote anti-theft alarm circuit
- Homemade anti-theft watchdog
- Inverter voltage starting circuit
- High voltage generator excitation group overvoltage protection circuit
- 7kW diesel engine thyristor voltage regulating circuit
- Reed relay spark elimination circuit
- DC electromagnet strong excitation fast pull-in circuit 4
- DC electromagnet strong excitation fast pull-in circuit 3b
- DC electromagnet strong excitation fast pull-in circuit one b
- Frequency sensitive rheostat automatic forward and reverse starting circuit
- Current relay secondary starting circuit
- Cam controller starting circuit
