Cam controller starting circuit
Source: InternetPublisher:aerobotics Keywords: Controller starting circuit contacts BSP Updated: 2020/04/13
158. A cam controller is often used to control the starting, speed and forward and reverse rotation of a winding asynchronous motor with a small capacity.
The cam controller starting circuit is shown in Figure 3-158. The cam controller handwheel has a total of 11 positions (see the contact opening and
closing table in the figure). The middle position is "0", and the motor does not move. There are five positions on the left and right, indicating the opening and closing status of the contacts during forward and reverse rotation
. "×" in the table indicates that the contact is closed, and the absence of this mark indicates that the contact is open. The cam controller has a total of 12 pairs of contacts. The top
4 pairs of contacts SAi~SA4 are used to control the forward and reverse rotation of the motor. The 4 contacts are equipped with arc extinguishing covers; the middle 5 pairs of contacts
xZl~x25 are used as switching resistors. Use; the bottom three pairs of auxiliary contacts SAs~SA7 are used in the control circuit.
- How to use a microcontroller to control a servo motor?
- Build a glove-controlled robotic arm
- A small improvement to the temperature and water level indicator alarm
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Design and manufacture of three-phase motor protection circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- Infrared detection alarm
- Bicycle anti-theft alarm
- "Watchdog" anti-theft alarm circuit
- Voice controlled flash LED light circuit diagram
- Straw returning to field crusher circuit
- DC ammeter
- AC voltmeter
- Double detuned loop frequency discriminator circuit
- Varactor Diode Frequency Modulator
- ring amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- color discrimination circuit
