toothache
MAXREFDES74#: 18-bit high-precision data acquisition system
The MAXREFDES74# reference design performs high-speed, 18-bit, high-precision data acquisition and is based on Maxim's leading-edge, high-precision, low-power data converters . MAXREFDES74# is designed as a module for high-speed, low-power, high-precision data acquisition and control systems in industrial process control and automation , as well as high-speed protection systems in power distribution and automation. 16-bit data acquisition systems can also be tested with pin-compatible 16-bit ADC and DAC devices such as the MAX11166 and MAX5316 .
Features of the MAXREFDES74# reference design include:
  • Power and data isolation
  • Flexible, configurable inverting or non-inverting input method
  • Unipolar or bipolar input (ADC) and output (DAC)
MAX11156
  • 18-bit resolution, no missing codes
  • Signal-to-noise ratio: 94.4dB
  • Total harmonic distortion: -107dB @ 1kHz
  • Buffered internal or external voltage reference input
  • Internal reference has a temperature coefficient of -6ppm/°C (typ)
  • 5V single power supply
  • True bipolar ±5V input range
MAX5318
  • High accuracy ±2 LSB INL (maximum)
  • 3µs settling time
  • User programmable offset and gain calibration
  • ±0.5ppm/°C (typ) offset and gain drift (all temperature range)
  • Loading/sensing output
  • 50MHz SPI compatible interface, 1.8V to 5.5V logic levels
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 20:24:36
