containsmachine
MAXREFDES39#: Power Amplifier Biasing with MAX11300 PIXI
The MAXREFDES39# power amplifier (PA) bias reference design uses the MAX11300 to bias and monitor PAs in RF base station system applications. Infineon's PTMA210152M-20W is used in this example, but any other power amplifier can be used. The MAX11300 provides a highly integrated solution for RF power amplifier bias infrastructure. The design uses all MAX11300 analog peripherals, requiring only one MAX11300 to bias and monitor the 2-stage RF power amplifier. Features of the reference design are as follows:
  • Frequency Division Duplex (FDD) and Time Division Duplex (TDD) radio frequency (RF) power amplifier monitoring, bias configuration and control.
  • Monitoring function
    • Highly accurate measurement of voltage and current
    • Measure current with Maxim's current-sense amplifier ( MAX44285 )
    • Drain voltage and current of primary and secondary amplifiers
    • Two external and one internal temperature monitors
    • Gate Bias for Primary and Secondary Amplifiers
  • control function
    • RF PA quick on/off
    • Synchronous TDD functionality
    • High Efficiency, Adjustable Drain Voltage Power Supply
    • LED signals and alarms
    • Automatic control function
    Figure 1. MAXREFDES39# system block diagram
    The USB interface to the microcontroller and the serial port to the MAX11300 are isolated from the main circuit through the MAX14850 . The microcontroller part is powered via USB, while other circuit parts are powered by an independent 36V DC power supply. Figure 1 also includes the power supply control and monitoring of the RF PA.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 22:44:33
