Lemontree
Multifunctional op amp based expansion board for STM32 Nucleo
X-NUCLEO-IKA01A1
The X-NUCLEO-IKA01A1 is a multifunctional expansion board based on STMicroelectronics operational amplifiers. It provides an affordable and easy-to-use solution for various use cases with your STM32 Nucleo board. The X-NUCLEO-IKA01A1 is compatible with the Arduino™ UNO R3 connector, and supports the addition of other boards that can be stacked for enhanced applications with an STM32 Nucleo board. It can be used as an analog front-end by conditioning signals as actuator to drive LEDs or coils, or in a comparator architecture.
Thanks to its current-sensing configuration, it allows current measurement of any device that has a Micro-USB port. A highly accurate TSZ124 Micropower operational amplifier is used for this configuration as well as for that of the instrumentation amplifier. The expansion board also contains a TSU104 Nanopower op-amp and a TSV734 Micropower op-amp for mobile applications.
Main features
  • 7 predefined configurations:
    • Instrumentation amplifier structure
    • Current sensing with or without USB
    • Photodiode/ultraviolet (UV) current sensing
    • Buffer
    • Full wave rectifier
    • Constant current LED driver
    • Window comparator
  • One prototyping area
  • Compatible with STM32 Nucleo boards
  • Comprehensive free development firmware library (X-CUBE-ANALOG1)
  • Powered through the Arduino UNO connectors
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 21:33:26
