smallembedded
Six-step brushless motor driver evaluation board based on STSPIN32F0B BLDC controller application
STEVAL-SPIN3204
The STEVAL-SPIN3204 three-phase brushless DC motor driver board is based on the STSPIN32F0B 3-phase BLDC controller with triple half-bridge gate driver, single shunt resistor current sensing topology and programmable overcurrent protection.
The motor controller system-in-package includes an STM32F031C6 microcontroller ready to execute 6-step, field oriented control (FOC) and other advanced driving algorithms in the firmware, which can be downloaded onto the chip flash memory via the board USB port.
The board is designed to help you test and develop motor control designs for applications such as power tools, home appliances, fans and pumps, with a flexible evaluation platform that even allows you to toggle between external sensor and sensorless position feedback data methods.
Main features
  • Input voltage from 7 to 45 V
  • Output current up to 15 ARMS
  • Power stage based on STD140N6F7 MOSFET
  • Embedded 3.3 V buck regulator
  • Embedded 12 V LDO regulator
  • Single shunt current sensing
  • Digital Hall sensors and encoder input
  • Overcurrent comparator
  • Bus voltage sensing
  • Embedded ST-LINK/V2-1
  • Easy user interface with buttons and trimmer
  • RoHS and WEEE compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 06:38:16
  • TDK82uH inductor replacement
  • The system time cannot be saved.
  • Asking for advice: When using ICCAVR to compile the OS_cpu_s.s file of ucos_II,
  • Using mbed to download to STM32 Nucleo board does not work properly
  • About the insensitive reception of 433 RF module
  • I'm confused, ST's software
