sigma
STC3105 based battery monitoring demonstration board with alarm output for gas meter application
STEVAL-ISB013V1
The STEVAL-ISB013V1 is a demonstration board based on the STC3105 battery monitor IC. The application monitors the voltage and current of a battery and includes a Coulomb counter to keep track of the charge/discharge status.
An alarm output signals a low state-of-charge (SOC) condition and/or low battery voltage. In addition, a relaxation register begins counting when the gas gauge is in a specified light-load condition, indicating when an OCV (open circuit voltage) measurement should be made for SOC correction.
Main features
  • Accurate battery voltage measurement
  • Coulomb counter to monitor the battery state-of-charge (SOC)
  • Internal 32.768 kHz time base
  • Low-battery alarm output with programmable SOC and voltage thresholds
  • Relaxation timer to track load condition (user-programmable load current threshold)
  • I2C interface for battery monitoring and device control
  • Low power consumption:
    • 100 μA in active operating conditions
    • 50 μA in power saving operating conditions
    • 2 μA in standby mode
    • 1 μA in power-down mode
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 02:30:54
  • Touch screen sampling problem (after each startup, the sampling value of the same point varies greatly)
  • Some things to know about PCB design
  • Can 430 be connected to 8255?
  • AVR timer compare mode problem
  • TF card receives design data
  • How does a mixed signal become a DC signal?
