super_star
Mains powered, 24V, 30W BLDC motor driver with efficient, high power factor power supply
TIDA-00652
To meet energy efficiency requirements, ceiling fans and ventilation fans will move from simple AC induction motors to brushless DC motors (BLDC). BLDC motors require AC-DC conversion with high efficiency and high power factor when operating on AC power. It also requires the use of highly efficient controlled inverters for low-noise operation. Reference design TIDA-00652 uses a single-stage power supply to convert an AC power input to a low-voltage DC output, helping meet the challenges of higher efficiency and power factor in a simpler way. It also incorporates a fully integrated and properly protected single-chip sensorless sinusoidal brushless motor controller for low-noise operation.
characteristic
  • ● Converts 230 VAC to 24 VDC using a high-efficiency single power stage
  • ● Using buck PFC topology, it can achieve high input power factor (>0.94) and high efficiency (>91%)
  • ● Universal input capability (50/60 Hz, 90-265 VAC) with minimal efficiency differences
  • ● Starts up and runs at full speed even with 90 VAC input
  • ● Highly integrated and properly protected single-chip sinusoidal brushless motor controller reduces external component count and helps avoid motor control programming overhead
  • ● Infrared remote speed control
Backlog Impt notice changes Backlog Impt notice changes end
参考设计图片
Blockdiagram
Search Datasheet?
Forum More
Update:2025-08-12 16:30:45
