sigma
Three-phase inverter based on STSPIN32F0602
EVSPIN32F06Q2S1:3-phase inverter based on STSPIN32F0602
The EVSPIN32F06Q2S1 board is a 3-phase complete inverter based on the STSPIN32F0602 controller, which embeds a 3‑phase 600 V gate driver and a Cortex®-M0 STM32 MCU. The power stage features STD18N65M5 MOSFET, but can be populated with any IGBT or Power MOSFET in DPAK or powerFLAT 8x8 HV package. The board has a single-shunt sensing topology, and both sensored and sensorless FOC and 6-step control algorithms can be implemented. This allows driving permanent magnet synchronous motors (PMSMs) and brushless DC (BLDC) motors.
The evaluation board is compatible with a wide range input voltage from 35 VAC (50 VDC) to 280 VAC (400 VDC), and includes a power supply stage with the VIPER06XS in flyback configuration to generate +15 V and +3.3 V supply voltage required by the application.
Debug and configuration of FW can be performed with standard STM32 tools through the detachable ST-LINK‑debugger. SWD and UART TX‑RX connectors are also available.
All features
Input voltage from 35 VAC (50 VDC) to 280 VAC (400 VDC)
STD18N65M5 MOS power stage featuring:
V(DS) @ TJmax= 710 V
RDS(on) max. = 0.220 Ω
Overcurrent threshold set to 8.5 Apeak
Dual footprint for IGBT/MOSFET package:
DPAK
PowerFlat 8x8 HV
Single-shunt current sensing, suitable for:
Sensored or sensorless 6-step algorithm
Sensored or sensorless single-shunt vector (FOC) algorithm
Smart shutdown overcurrent protection
Digital Hall sensors and encoder input
Bus voltage sensing
15 V VCC and 3.3 V VDD supplies
Embedded ST-LINK/V2-1
Easy user interface with buttons and trimmer
RoHS compliant
Search Datasheet?
Forum More
Update:2025-08-06 16:31:55
