兰博
VD6283 breakout board 6-channel ambient light sensor with advanced light flicker extraction function
VD6283TX-SATEL
The VD6283TX-SATEL breakout boards can be used for easy integration into customer devices.
Thanks to the voltage regulator and level shifters, the VD6283 breakout boards can be used in any application with a 1.8 V to 5 V supply.
The PCB section supporting the VD6283 module is perforated so that developers can break off the mini PCB for use in a 1.8 V supply application using flying leads. This makes it easier to integrate the VD6283TX-SATEL breakout boards into development and evaluation devices due to their small size.
所有功能
VD6283 6-channel Ambient Light Sensor (ALS) with advanced light flicker extraction
Regulator: 5 V to 1.8 V range input voltage (output voltage: 1.8 V)
VD6283 signal interface level shifter
Divisible board enabling use as mini PCB breakout board, easy to integrate in customer device
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 04:22:42
