ohahaha
Single relay module (5V, 12V)
product description
This 1-way relay module can be used in situations with large interference. It can be powered by two completely isolated power systems, ensuring that the relay will not affect the signal loop when switching. At the same time, it can also be freely switched to high-level drive mode. Or low level drive mode. The use of Songle's high-quality relays ensures that the module has a long service life.
  • Complete photoelectric isolation, dual power supply.
  • High-level drive mode or low-level drive mode can be switched at any time.
  • Songle original high quality relay.
Pin function table
GND2 Analogly
GND signal ground
VCC2 Analog power input (12V)
VCC Signal power input (3.3V-5V)
IN Control signal input (0-5V)
COM Relay output common contact
NO, NC Relay output normally closed contact, normally open contact
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 07:00:30
