蓝猫淘气
[Successful actual measurement] Solution verification board based on CH340G
This project is used to verify the solution verification design of LCSC's USB chip CH340G ( LCSC No. C14267 )
  • CH340 is a USB bus adapter chip that realizes USB to serial port or USB to print port.
  • Full-speed USB device interface, compatible with USB V2.0.
  • Simulates standard serial ports, used to upgrade original serial port peripherals, or add additional serial ports through USB. Computer side
  • Serial port applications under Windows operating systems are fully compatible and require no modification.
  • Hardware full-duplex serial port, built-in transceiver buffer, supports communication baud rate of 50bps~2Mbps.
  • Supports commonly used MODEM contact signals RTS, DTR, DCD, RI, DSR, CTS.
  • Through external level conversion devices, interfaces such as RS232, RS485, and RS422 are provided.
  • The software is compatible with CH341 and you can directly use the CH341 driver.
  • Supports 5V power supply voltage and 3.3V power supply voltage and even 3V power supply voltage.
  • Available in SOP-16 and SSOP-20 and MSOP-10 lead-free packages, RoHS compliant.
---------copy from datasheet
This solution verification board adds an 8V1.5A self-restoring fuse to the USB input. The main power supply line is 30mil wide and can pass 2A MAX current. This ensures that when a short circuit or overload occurs, the fuse will be blown first. After the problem is eliminated, it can be used directly, which almost avoids the problem of needing to replace the PCB due to burnt lines. This solution verification board defaults to 3V3 Level mode, suitable for 5V/3V3 level microcontroller, no adjustment required. This solution verification board leads to a total of 8 pins CTS/RTS/DTR/RX/TX/GND/5V/3V3
Attributes type
CTS MODEM contact input signal, clear to send I,#
RTS MODEM contact output signal, request to send O,#
DTR MODEM contact output signal, data terminal is ready O,#
RX serial data input I,pu
Tx Serial data output O,pu
GND power supply P
5V power supply P
3V3 power supply P
PCB blank board: QQ picture 20200414141620.jpg actual soldering diagram:QQ picture 20200414141624.jpgQQ picture 20200414141616.jpg
BGM: nameless story (Super Cannon T ED)
The serial port debugging installation package seems to have been deleted and will not be released. There are many online, just download it yourself.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 00:33:53
