ghaytweyhtoo
TM1640 digital tube module
Introduction
A 16-bit digital tube display panel module based on Shenzhen Tianwei TM1640 digital tube driver chip. The board carries four 0.36-inch four-bit common cathode digital tubes. The power supply and MCU drive signal input interfaces are introduced.
  • Only 2 wires are needed to drive, the interface is simple, and the microcontroller pins are saved.
  • Eight-level digital tube display brightness adjustment
  • A single TM1640 can drive up to 16-bit common cathode digital tubes or 128 LEDs
  • Current sinking into grid pin: maximum 200mA, typical value 140mA
  • Current drawn by seg pin: 50mA maximum, 25mA typical
  • Serial clock line CLK maximum clock frequency: 1MHz (50% duty cycle)
interface
  • VCC: The module power supply is positive, 3.3V or 5V is recommended
  • CLK: Synchronous serial communication clock signal input pin
  • DIN: Synchronous serial communication data input pin
  • GND: module power ground
Development library
Arduino platform : See the project attachment "TM1640_Arduino_library.zip". After downloading, extract it to the libraries directory of the Arduino installation directory and use it. There are related examples in the examples directory for reference.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 05:21:36
  • ARM and DSP
  • For self-control
  • PCB welding problem help
  • TMS570LC4357 PWM phase shift problem
  • I am a beginner in FPGA, and would like to ask about external memory.
  • AD Sampling Problems - AC Sampling
