王达业
AMG8833 thermal imaging camera
Introduction
A simple thermal imaging camera made using AMG8833. Equipped with an SD card slot, you can store the photos taken to the SD card.
characteristic
  • Using AMG8833 finished module, resolution 8x8. Increase resolution to 64x64 through interpolation algorithm
  • Supports iron red, white hot and rainbow color cards
  • It has the measurement functions of maximum temperature, minimum temperature, average temperature and core temperature.
  • Lithium battery power supply and charging management function
  • Battery level display
  • Supports saving current photos to SD card
Some points to note
  • For the screen, choose the 128x160 resolution commonly found on Taobao and the small LCD screen module of the 1.8-inch ST7735S controller. Remember to choose the one with a 14Pin plug-in. The general price is between 10 and 15 yuan
  • Pay attention to the size and thickness of the battery. It is not recommended to exceed 30x20x6mm.
  • The crystal oscillator does not need to be soldered (because precise timing is not needed)
  • It’s just a fun picture. Just look at the hot spots and take some photos of deep well ice. Don’t have too high expectations for accuracy.
  • It freezes when taking photos.
  • If there are problems during production, check the welding first. 90% of the problems are caused by welding problems, including tin, missing soldering, and wrong components. Check it carefully and re-solder it if necessary.
Take sample photos
iron red card
Rainbow color card
white hot color chart
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 14:31:18
