念慈菴
STM32H743Ix/F767Ix core board
Introduction
176Pin STM32H743/F767 core board (STM32H743Ix/STM32F767Ix), onboard 256Mbit (32MByte) 16-bit SDRAM and QSPI NOR Flash. It is convenient to evaluate the performance of F767/H743.
The supporting screen + debugger has also been open sourced, address: H743II core board supporting 3.5-inch IPS capacitive touch screen module
characteristic
  • Supports STM32H743/F767 in 176Pin LQFP package
  • Onboard 256Mbit (32MByte) 16-bit SDRAM
  • Onboard NOR Flash, uses Quad-SPI interface for communication
  • 3 LED lights, one of which is the power indicator light and the other two are available for users
  • 4 touch buttons, including a reset button and a BOOT mode switching button, and the other two are available for use. KEY_UP among them has sleep wake-up function.
  • Micro-SD card interface, using SDMMC 4bit bus communication
  • 5V and 3.3V power supply pin headers can facilitate peripherals to draw power.
  • A dedicated LCD interface designed to be compatible with most common small LCDs (available when SDRAM is not used) and dedicated parallel LCD modules
  • Lead out all IO ports except NOR FLASH and SDRAM address lines/control lines.
  • Micro-USB interface, with 1.5K pull-up resistor on DP. With 500mA overcurrent protection function.
  • CR1220 battery holder pad reserved for RTC power supply
  • Double-layer board, conventional process, effectively saving proofing costs.
  • All components except the CR1220 battery holder are on the front and are SMT-operated.
Performance test report
The test results will be affected by external conditions and the components themselves and are for reference only.
peripherals Test items Test Conditions Test Results
SDRAM Maximum operating frequency All 0s, all 1s, sequence, three items written and read without error 120MHz
SDRAM Maximum writing speed Use MDMA to write 256KB, frequency 120MHz 1696Mbps (212MB/s)
NOR FLASH Maximum operating frequency After writing in the normal way, reading in memory mapping mode has no error. 133MHz
SDMMC Maximum operating frequency After initialization, using FatFS to write a test text file without errors 25MHz
Physical picture
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 23:21:59
