太白金星
SC8721QFER solution verification board
This project is based on Nanxin SC8721QFER solution verification board (C429907) SC8721 high-efficiency synchronous buck-boost converter, which integrates four low internal resistance MOS SC8721 is an ultra-high efficiency synchronous Buck-Boost that integrates four power tubes The converter simplifies customer system design to the greatest extent, reduces PCB Space and BOM, and its high efficiency can effectively reduce heat loss. The output voltage of the SC8721 can be higher than, equal to or lower than the input voltage. SC8721 has an ultra-wide input and output voltage range, and the input and output voltage range can reach 2.7V to 22V. SC8721 integrates I2C function to facilitate customers to use the control chip. Users can configure the output voltage, output current limit and switching frequency through I2C. SC8721 adopts current control mode and supports output current limit, dynamic output voltage adjustment, internal current limit, output short-circuit protection and over-temperature protection to ensure that the chip can work under various abnormal conditions. SC8721 is packaged in 21pin 4x4 QFN. Has the following advantages
  • High Efficiency Buck- Boost Conversion
  • Integrated Switches, 10 mQ for Q1/4, 20 mQ for Q2/3
  • Wide VIN Range: 2.7 V to 22 V, 25V sustainable
  • Wide VOUT Range: 2.7 V to 22 V, 25V sustainable
  • Dynamic Output Voltage Control
  • Adjustable Switching Frequency
  • Output Voltage Cable Drop Compensation
  • I2C Programmable Output Voltage
  • I2C Programmable Output Current Limit
  • Output Current Monitor
  • Under Voltage Protection, Over Voltage Protection,
  • Over Current Protection
  • Short Protection
  • Thermal Shutdown Protection
  • QFN-21 4 X 4 Package
Using IIC communication
This solution verification board leads out the SW probe to facilitate observation of the waveform.
The CSO probe is a current sensing probe
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-08 13:57:23
