6IA2H
UCC24624_MOS synchronous rectification
Energy-saving synchronous rectification, the three-terminal coil is connected, the positive and negative are added to the ground, and the positive and negative coils are required to be symmetrical. The size is 10*10mm. The power supply of the rectifier chip has voltage withstand requirements. You need to use diodes to build the same circuit first and test that the output voltage is less than the power supply limit, and then remove and solder it to avoid burning the chip.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 12:35:20
  • MSP430 entry-level program: timed flashing
  • F28335 external interrupt example sharing
  • Use Solve
  • How to play rm format files under wince?
  • [Raspberry Pi 4B Review] + Building a file server
  • CCS asked for advice!!!
