ohahaha
WIFIduino ESP32
This project is modeled after the design of WIFIduino, but the pin order is different.
The project uses the Arduino Uno outer frame. The upper and lower rows of main pins are the same as the Uno pins. The matching shell can be used directly (if other internal pins are not used). ESP-WROOM-32 has all pins, you can select the appropriate pins for use.
参考设计图片
Search Datasheet?
Forum More
Update:2025-06-28 02:35:06
