太白金星
[Tuya Smart] IoT Thermometer
This is a thermometer with an ambient light function that can also be used as a night light. You can use Tuya APP to obtain temperature and humidity data in real time, and can turn on and off the ambient light regularly to realize the night light function. You can also associate the color of the ambient light with the temperature and humidity data so that the temperature and humidity data can be displayed intuitively. It also supports RGB The running water lamp can be placed inside the chassis and charged through the USB interface to monitor the temperature and humidity data inside the chassis in real time. And it can save internal data in real time and will not be lost when power is turned off.
Introduction to application scenarios
  1. Place it inside the host, chassis, and other equipment, and use running lights to replace the RGB light strips inside the chassis to achieve lighting effects.
  2. Paste it in the bathroom, bedside and other places that are prone to danger after getting up at night, adjust the RGB brightness and color to a soft state that does not affect sleep, and turn on cloud timing to use it as a night light that can light up regularly.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 07:21:55
