张三叔
BTN7971B module_high power H-bridge driver
  • This module can be used to drive high-power DC brush motors, or used in smart car competition motor drive boards.
  • The module uses Infineon BTN7971B half-bridge driver IC. The gate driver circuit is integrated inside the IC, eliminating the need to design an external gate driver circuit.
  • Rated input voltage: 6-28V (recommended not to exceed 35V)
  • PWM input frequency: 1KHz-10KHz (PWM signal frequency too high will cause serious heating)
  • Onboard single channel total 660UF power supply filter aluminum electrolytic capacitor
  • The maximum current of a single channel can reach 90A, but good heat dissipation conditions need to be provided for the module
  • There are two interfaces for signal input, conventional DuPont cable interface and 0.5mm pitch FPC cable interface
  • The input signal is isolated and compatible with 3.3V and 5V levels
  • Taking into account the protection of the MCU, the module has a high-impedance input and a 4.7K resistor in series to limit the current under extreme conditions.
  • The module EN enable default 4.7k resistor is pulled down to ground, and the two driver ICs share an EN enable signal.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-02 22:05:19
