石榴姐
Lithium battery charging, protection and boost module integrated board
Lithium battery charging uses TP4056 charging chip engineering features: - Charging safety , DW01 combined with MOS field effect tube to avoid dangerous situations such as overcharge, over-discharge, and short circuit during charging. -Two outputs , select the 10K and 27K resistors in HX3608 through the switch to provide two outputs of 5V and 12V respectively, with an output current of 1A. Instructions for use: The charging module supports adjusting the output voltage during the charging process, but the prerequisite is to turn off the power switch first and then adjust the voltage. A general understanding, the project is presented.
Search Datasheet?
Forum More
Update:2025-07-05 17:48:16
