张三叔
Server cheap power supply transformation standard atx plan-1U power supply-atx power supply-plug-in part
Connect to https://lceda.cn/zhao1999250/12vo-atx_copy_copy_copy_copy_copy_copy
This is the 6 8pin and two hard drive 5pin version, just solder it
Note that it is best to solder the lower pin on all four sides. That is, after it is plugged into the dcdc board, there will be solder on the bottom and above, like an xy coordinate axis, four quadrants, and all four sides are filled with solder.
In addition, the plug-in direction is outward. If you plug those wires inward, it will short-circuit.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 18:42:38
