sigma
STM32F103RCT6 core board backplane
  • The base board, core board and small modules together form a development board. The core board is separated from the main board, which facilitates replacement and saves time for repair. The board provides a variety of standard interfaces, which can facilitate experiments with various peripherals. and development, many resources on the board can be flexibly configured to meet use under different conditions. We have introduced all the IO ports except the IO port occupied by the crystal oscillator, which can greatly facilitate everyone's expansion and use. Each interface is marked with silk screen, making it clear to use; the interface location is designed and arranged reasonably, making it convenient and convenient.
  • Technical Parameters:
  • 1. The base board is used with the STM32F103RCT6 core board.
  • 2. Use board-to-board connectors for plug-in connection, which is more convenient to use and maintain.
  • 3. The connector has connection direction indication and anti-reverse connection function
  • 4. Mark the connection direction on the detachable part.
  • 5. Lead out all IO ports except the IO port occupied by the crystal oscillator.
  • 6. The input and output parts of the power supply are led out to facilitate supplying or taking power to other modules.
  • 7. Onboard JTAG download and serial port download
  • PCB blank board:
  • Physical picture of completed welding
8AFDC6C317F58E4678F3383F39C1385C.jpg -Dimensions
  • The experiments that can be done on the development board include
  • 1. Running water lamp experiment
  • 2. Buzzer experiment
  • 3. Press the button to light up the LED experiment
  • 4. Interruption control experiment
  • 5. Serial port experiment
  • 6.LCD display experiment
  • 7. Window watchdog experiment
  • 8. Independent watchdog experiment
  • 9. Timer experiment
  • 10. Standby experiment
  • 11.PWM experiment
  • 12.ADC experiment (external ADC/DHT11/DS18B20 experiment module)
  • 13.CPU monitoring temperature experiment
  • 14.RTC experiment
  • 15.EEPROM experiment (external EEPROM experiment module)
  • 16.FLASH experiment (external FLASH experiment module)
  • 17.SD experiment (external SD experiment module)
  • 18.DS18B20 experiment (external ADC/DHT11/DS18B20 experiment module)
  • 19.HS0038 infrared experiment
  • DS18B20 temperature measurement experiment P0051213530.jpg -CPU internal temperature measurement experiment P005121357 0.jpg
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 23:42:50
