通通
MAXREFDES1209: Non-isolated 12V/0.5A 6W step-down converter using MAX17501
MAXREFDES1209: Non-Isolated 12V/0.5A 6W Step-Down Converter Using the MAX17501
The MAXREFDES1209 operates over a 14V to 60V input voltage range to deliver output voltage regulated at 12V and up to 500mA of load current. The output voltage is accurate to within ±1.7% over -40°C to +125°C. The MAX17501 EV kit is available in a compact TDFN package. The device features peak-current-mode control with pulse-width modulation (PWM) with a fixed switching frequency of 600kHz at all loads. The device offers external compensation components and uses a two-layer PCB board. The low-resistance, on-chip MOSFETs ensure high efficiency (~94%) at full load and simplify the layout. A programmable soft-start feature reduces input inrush current. The device also incorporates an output enable/undervoltage lockout pin (EN/UVLO) that turns on the part at the desired input voltage level. An open-drain RESET pin provides a delayed power-good signal to the system upon achieving successful regulation of the output voltage.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 08:15:06
  • DIY Engraving Machine
  • [Low Power] Artix-7 FPGA Series Data Collection (Part 1)
  • Wince channel switch!
  • About TMS320F28035
  • Introduction to Msp430 timer and its basic applications
  • To embedded system beginners----Chuanke Innovation (CTIC)
