0kWAbUK1E
20-key 4-knob keypad
Verified, Gerber, firmware, firmware source code, and shell drawings are attached.
⚠️Auto-routing warning
⚠️Dirty board warning
2022.01.17  Added welding and hot-swappable dual-use version, this version uses SMD diodes, verified
2022.03.01 firmware adds counterclockwise rotation 90° layout
2022.07.13 Add stacked shell drawing
Series Notes
(1) Zero-based assembly of open source keyboard
(2) Draw your own drawing board and have enough food and clothing
(3) Make a knob keypad
keyboard list
51-key keyboard
51-key orthogonal keyboard
16-key 4-knob keypad
Fake split keyboard
Fake split keyboard (orthogonal)
Dimensions (unit: cm)
name long Width
PCB 10 9.525
Positioning plate
base plate
material list
serial number Essential name quantity Remark
1 1N4148 diode twenty four
Hot-swappable version: direct plug-in (1N4148 DO-35)
Welding hot-swappable dual-purpose version: SMD type (1N4148 LL34 1206)
2 Shaft 20
3 Kaihua hot-swappable shaft base 20 Welding hot-swappable dual-purpose version can save
4 EC11 encoder 4 Plum blossom handle, height optional
5 knob cap 4 Plum blossom handle, height is arbitrary, width is about 23mm (the bottom one can be increased by 30mm)
6 Pro Micro Development Board 1 Buy one that comes with BootLoader
7 12pin pin header 2 It is used to connect the development board and PCB. It is usually given when buying a development board.
8   40pin header 1 It is convenient to disassemble the development board; cut it into 2x12pin for use; if you use a female header, you need to buy the corresponding pin header, or use the cut diode pins
9 Positioning plate 1 Welding hot-swappable dual-purpose version can save
10 M2 screw 10 5 holes on the positioning plate + 5 holes on the bottom plate, recommended heights 5mm and 10mm
11 M2 nut 5 Height 10 mm or more
12   4.5x4.5mm four-pin chip micro switch 1 Used for short-circuit-free brush firmware; height below 6mm
Shell material table (unit: mm)
serial number name length quantity Essential Remark
1 M2 nut 20 8 Connect positioning plate and mezzanine
2 10 2   For foot support
3 M2 screw 10 8 Connect the upper cover and positioning plate
4 6 8 Connect mezzanine to base plate
5 5 4   Connect the legs to the base plate
(A total of 6 acrylic sheets, recommended tb stores: Luoman, Yixin Plastic Industry, Sandi New Materials, Shenghui)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 12:20:22
