mQQpgDwhoh
【Training Camp】Crazy and Crazy
PCB design instructions
Note that lines with high currents only need to be wider, and make some heat dissipation holes for the LDO.
Software description
The firmware uses Ubuntu provided by the training camp and opens clion to edit and generate. I am a novice and only changed the length of the dogleg in genkipi (the one I drew is different from the one provided), and the angle data sent by json in the html framework to achieve progress. Squat down, a movement to attract wealth (waving your hands).
Code block:
<!DOCTYPE html><html lang="en"><head><meta charset="UTF-8"><title>cheems for xyz</title><style> body {user-select: none;text-align : center;} table {margin: 0 auto} td div {width: 150px;height: 150px;border: 1px solid darkgrey;display: flex;align-items: center;justify-content: center;color: black;} # s {background-color: red;color: white;} td div:active {background: deepskyblue;color: white;} button {margin: 0.5rem;width: 9rem;height: 3rem;font-size: 1.2rem;border -radius: 1rem;} button:hover {border-radius: 1rem;background-color: deepskyblue;color: aliceblue;}</style></head><body><h1>Control cheems modification hook</h1>< button id="a">Mecha returns</button><br><br><button id="b">Stay where you are</button><br><br><button id="c"> Asian Squat</button><br><br><button id="d">Forward Test V1.0</button><br><br><button id="e">Lucky</button>< br><br><button id="f">Under development</button><br><br><button id="g">Under development</button><br><br><script> function u (p) {return ${p};}function g(i) {return document.getElementById(i);}function fe(e, f) {e.addEventListener('click', function (e) {/* do something*/f();});}function fg(u, f) {let x = new XMLHttpRequest();x.onreadystatechange = function () {if (this.readyState == 4 && this.status == 200 ) {f(x);}};x.open("GET", u, true);x.send();}function fp(u, d, f, p) {let x = new XMLHttpRequest(); if (p) {x.upload.addEventListener('progress', function (e) {p(e);});}x.onreadystatechange = function () {if (this.readyState == 4 && this.status = = 200) {f(x);}};x.open('POST', u, true);x.timeout = 45000;x.send(d);}fe(g('a'), () => {fg(u('/dog/init'), () => {});});fe(g('b'), () => {let data = {"type": 3, "count": 30, "list": [[75, 115, 25, 155, 25, 155, 75, 115, 100], [25, 155, 75, 115, 75, 115, 25, 155, 100] ]};fp(u('/dog/cmds'), JSON.stringify(data), () => {});});fe(g('c'), () => {let data = {"type": 3, "count": 30, "list": [[30, 90, 8, 130, 30, 90, 8, 130, 100]]};fp(u('/dog/cmds' ), JSON.stringify(data), () => {});});fe(g('d'), () => {let data = {"type": 3, "count": 30, "list": [[10, 108, 95, 176, 71, 177, 26, 134, 200], [49, 146, 42, 197, 42, 197, 49, 146, 200], [71, 177, 26, 134, 10, 108, 95, 176, 200], [42, 197, 49, 146, 49, 146, 42, 197, 200]]};fp(u('/dog/cmds'), JSON .stringify(data), () => {});});fe(g('e'), () => {let data = {"type": 3, "count": 30, "list" : [[30, 90, 8, 130, 30, 90, 8, 140, 150],[0, 100, 8, 130, 30, 90, 8, 140, 150]]};fp(u('/ dog/cmds'), JSON.stringify(data),() => {});});fe(g('f'), () => {let data = {"type": 3, "count": 30, "list": [[74, 111 , 24, 151, 24, 151, 74, 111, 100], [24, 151, 74, 111, 74, 111, 24, 151, 100]]};fp(u('/dog/cmds'), JSON.stringify(data), () => {});});fe(g('g'), () => {let data = {"type": 3, "count": 30, "list ": [[74, 111, 24, 151, 24, 151, 74, 111, 100], [24, 151, 74, 111, 74, 111, 24, 151, 100]]};fp(u(' /dog/cmds'), JSON.stringify(data), () => {});});</script></body></html>
Physical display instructions
L35TX2Q5{1MZ~5}3)YLM8WJ.jpgFull body 3D printing
Precautions
When encountering a situation where programming cannot be performed, use an electric meter to check the potentials one by one. This time, it is because of the switch packaging problem that the enable terminal EN has been wasting a lot of time.
Demo video
see attached
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-02 15:36:03
