宋元浩
29 Programmer EEPROM29
gitee address
https://gitee.com/happysoul/eeprom29
Main functions available
Read and write: 29 series eeprom
Erase: Erase the entire eeprom to 0xff
Blank check: Query non-FF data
Verification: Compare with file content after programming
Chip information: There is still a problem with this function
Chip space problem (Atmega8a only has 8k rom space) and only supports 32-pin 29 series flash chips
Tested A29040, MX29F040, SST39F040, W29C020 (Winbond)
There is a small probability that the chip above will fail to write. You can use the erase function to restore the chip to FF before writing data. If the chip is damaged due to too many erases and writes, no matter what kind of writer, it may not be able to write normally.
I have tested using a multi-pin chip to read and write directly. Due to the output current and voltage problem, the written data is unstable. I used 595 instead of IO to directly connect the eeprom pin to provide stable voltage and current.
Developed using Arduino software and Python3+QT5 on PC
Arduino needs to add atmega8a support
Add json
Other optional chips
Atmega8 88 168 328 can be A, P, PA, PB cannot be used because the PIN definition is different
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 06:21:34
