张三叔
Two-way driver L298N
L298N is the vertical package of L298. It is derived from the brand product of STMicroelectronics Group. It is a dual-channel full-bridge motor driver chip that can accept high voltage and high current. The operating voltage can reach 46V and the output current can reach up to 4A. It adopts Multiwatt 15-pin package, accepts standard TTL logic level signals, and has two enable control terminals. It can dynamically adjust the circuit operation mode by plugging and unplugging the onboard jumper without being affected by the input signal. There is a logic At the power input end, the built-in voltage stabilizing chip 78MO5 allows the internal logic circuit part to work at low voltage, and can also output a logic voltage of 5V to the outside. In order to avoid damage to the voltage stabilizing chip, when using a driving voltage greater than 12V, be sure to use an external The 5V interface is independently powered.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 12:47:51
