石榴姐
[Graduation] Design of household appliance switch control system based on GSM
1: Graduation task design requirements
       Under the background of the widespread popularity of smart homes and smart phones, this topic proposes a smart home appliance switch control system with remote monitoring and remote control functions based on GSM smart phones, taking the currently popular smart home as an entry point. .
       The specific requirements for the home control system based on the GSM mobile network platform are as follows:
    (1) Using the GSM mobile phone network as a platform, remotely query the switch information of four-way household appliances.
    (2) User telephone inquiry, the system sends the switch information of household appliances to the user terminal through SMS.
    (3) Users can control the on and off status of four-way household appliances by sending text messages.
    (4) The four-channel home appliances in the home use centralized control. When there is no remote control, they form a centralized control system. Android phones can be used to realize remote control on and off functions.
    (5) The switch is controlled by a relay, and the relay current is 10A.
IMG_256
Figure 1 Design flow chart explanation
Two: Design plan
Power supply: The Hailingke HLK-10M05 ultra-small series module is used to convert household 220V power into V direct current. The post-stage circuit uses UTC (Youshun) 3.3V LDO to step down and provide working voltage for the microcontroller and relay. Provides a variety of operating voltages at all levels.
Main control: Choose STM32LO53C8T6 microcontroller and 3 UARTs to meet the system design requirements. Other redundant ports can be used to expand other functions.
GSM module: select SIM900A. Use a 4G mobile phone card. The reason for choosing this module is the convenience of supporting 4G mobile phone cards.
On the relay module: select Taobao four-way relay and select low level trigger.
Key switch input design: use light touch key switch 12*12mm round micro switch, buy it and design the circuit board yourself and weld it yourself.
Figure 2 Schematic diagram of design plan
Three: Programming
System initialization includes: GPIO initialization, serial port initialization, etc. After the initialization is completed, enter the module communication program, followed by the offline button processing program. If the system receives text messages and phone calls, it will perform text message and phone call data processing procedures.
I will introduce the important program flow chart here, and other simple codes will be understood by everyone here and will not be embarrassing.
wps
Overall system flow chart
Step one: Use STM32CubeMX initialization code program. Configure each GPIO port to meet functional requirements.
Secondly, select the appropriate clock frequency, and select the internal clock frequency of 16MHz. The development board has an 8MHz crystal oscillator, but if it does not, the internal crystal oscillator is used.
I introduced the serial communication program and AT command sending function by referring to the video of Lichuang EDA that I wanted to know in detail. I modified it according to this.
Link    https://www.bilibili.com/video/BV1eV411t7fn?p=28
This is the serial port generation function that I understand
The specific process of serial port implementation is that when USART1 receives the debugging information sent from the computer, it enters the serial port 1 interrupt, waits for the completion of data transmission, and the microcontroller sends the received data to the GSM module through serial port 2. The module sends the data to the microcontroller through serial port 2, and then the microcontroller forwards the data to the computer. Implemented AT command debugging of the module by computer. It facilitates the debugging process of later AT writing.
This is my AT command generation function
The previous two programs realize efficient AT command control between the microcontroller and the module. At the same time, the computer side can also receive the debugging information returned by the module. The module information identification program I designed includes an SMS phone data processing program, an SMS communication identification program, and an SMS sending program.
The implementation is to call the above function and provide the encapsulated uint8_t Send_Cmd (uint8_t *Cmd, uint8_t Len, char *recdata) for execution. Please see my demonstration video for the specific implemented functions.
This subroutine first parses the AT commands sent by the GSM module. When a call is made to the GSM module, the module will return the "RING" character to the microcontroller through the AT command. When the microcontroller receives the character and waits for 5 seconds to hang up to make the call, it will read the system status and send the system information to the preset via SMS. on a mobile phone when accepting an instruction received other than a phone call. The microcontroller detects whether the GSM module has received the text message. When the "+CMTI: "SM",XXX" character is detected, the text message information at that location is read. At the same time, it is identified whether there is a setting instruction in the text message. For example, when the "query" instruction text message is received, the system status is read and the system information is sent to the preset mobile phone via text message. If it is not the time to "query" text messages, other instructions will be detected. For example: when the "open all sockets" command is detected, all relays will be turned on.
The language recognition program has not been perfected yet and will be released after it is perfected. At present, only language recognition has been implemented, and serial port communication has not been completed.
Four: Control instructions
The supported commands are as follows
User action
Command content
System execution action
Call to check the status of electrical switches
Send system electrical switch status information
Query electrical switch status via SMS
Inquire
SMS control electrical switch status
Open socket one
Open relay one
Turn off socket one
Close relay one
Open socket two
Open relay two
Close socket two
Close relay two
Open socket three
Open relay three
Close outlet three
Close relay three
Open socket four
Open relay four
Close socket four
Close relay four
Note: Designate users to receive text messages.
Five physical demonstrations
Demonstration video: Graduation project-Design of home appliance switch control system based on GSM_bilibili_bilibili
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 08:16:11
  • I am new to TMS320LF2407, please tell me about the loading program
  • How to connect two GPRS modules?
  • TA output mode question
  • Definition and application of 4~20mA test function of multimeter
  • About ADXL345 sampling rate
  • Microcontroller low power design resources
