黄土马家
ESP32 PicoD4 USB plug-in minimum system development board
         You can directly plug in the USB for programming, eliminating the trouble of data cables. The esp32 packaged in pico-d4 is compact and can be plugged into a breadboard. It has an automatic download circuit and is pin-compatible with Wemos Lolin32 lite, but introduces Vin and +5V pins to facilitate breadboard development and expansion board power supply.
          The project has been verified and works fine. Note: Do not use pins 16 and 17 when writing code, and do not use UART2 directly. Just replace pins 16 and 17 with pins 9 and 10.
BOM download
PCB_PCB_ESP3-PicoD4_2022-09-25.pdf
PCB_PCB_ESP3-PicoD4_2022-09-25.json
PCB_ESP3-PicoD4_2022-09-25.pcbdoc
Gerber_PCB_ESP3-PicoD4.zip
Schematic_ESP32 PicoD4 USB plug-in minimum system development board_2022-09-25.pdf
SCH_ESP32 PicoD4 USB plug-in minimum system development board_2022-09-25.json
Sheet_1_2022-09-25.schdoc
61118
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 23:56:49
