ohahaha
STM32L431 core board
The pins are all out, and there is only a minimal system and a TL431 voltage reference on the board.
This chip features low power consumption, 16-bit 5Msps ADC, and FPU
BOM download
PCB_PCB_STM32L431_2022-09-24.pdf
PCB_PCB_STM32L431_2022-09-24.json
PCB_STM32L431_2022-09-24.pcbdoc
Gerber_PCB_STM32L431.zip
Schematic_STM32L431 core board_2022-09-24.pdf
SCH_STM32L431 core board_2022-09-24.json
Sheet_1_2022-09-24.schdoc
61268
TYPEC input adjustable power supply
Introduction: type-c input, up to 20V5A 100W buck-boost adjustable power supply
SC8903 buck-boost chip + fs312 fast charge decoy chip + INA199A2 current sensing amplifier + PW6206LDO + STC8G1K08A microcontroller.
Except for 8903, which is more expensive, other chips are about one yuan. The voltage can be adjusted between 3.1-20V, and the current can be between 0.4-5A. When adjusting the maximum 100W
output ripple at no load, it will be between 3-20mV depending on the output voltage, and the 4.5A output will not exceed 40mV.
The output efficiency of 16V5A is 93%.
The efficiency of 18V4.5A output is 94%.
The following two ripple diagrams are the ripples at 16V at no load and at 4.5A output.
The microcontroller model is STC81K08A. There must be an A suffix, otherwise there is no on-chip ADC. Download When burning the microcontroller program, select 24MHZ as the frequency of
the microcontroller, connect the TX of the downloader to the RX on the board, and the RX to the TX on the board; first connect the three wires GND TX RX, click Download Program on STC-ISP and then plug in the VCC
potential The resistance of the device may be quite different. Adjusting the output voltage may exceed 22V, which will trigger the overvoltage protection of the chip. When adjusting, be careful not to twist it all the way.
It can adjust the current and has a constant current function, but do not short-circuit it directly. The current inside the SC8903 The charging head that pulls
the front stage of the amplifier should try to use a fast charging head that supports 100WPD. If the overpower is insufficient, be careful not to exceed the power of the charging head when using it, otherwise the over-current protection of the charging head may be triggered.
sc8903+stc8g1k0a.hex
BOM download
PCB_PCB_SC8903_2022-09-24.pdf
PCB_PCB_SC8903_2022-09-24.json
PCB_SC8903_2022-09-24.pcbdoc
Gerber_PCB_SC8903.zip
Schematic_TYPEC input adjustable power supply_2022-09-24.pdf
SCH_TYPEC input adjustable power supply_2022-09-24.json
61269
6-way USB power distributor + power meter OLED display
Introduction: A compact 6-way USB switch, + power meter OLED display.
Regarding hardware, as there are more and more small devices with various functions on the desktop, most of them are powered by USB interfaces. So I designed this small device to support a total of 6 USB interface outputs. Controlled by 4 torsion switches. It also supports monitoring the power of each USB output. 3 display modes. Only total power can be displayed. USB voltage, current, power of each channel, etc. It has relatively practical functions.
The main control is STC's 8G1K17A-SOP16. The source code can be used with other models of the 8G series. Already open source. You can join the group "967261086" and download all design materials for free. More small software and hardware works will be open sourced in succession. Everyone is welcome to discuss together.
video.mp4
BOM download
Schematic_6-way USB power distributor + power meter OLED display_2022-09-24.pdf
SCH_6-way USB power distributor + power meter OLED display_2022-09-24.json
U6_2022-09-24.schdoc
61270
Relay module
Introduction: A relay module that can switch switches and delay
The delay time can be adjusted by soldering different capacitors
Voltage: 5v
Current: 5a
Note: Click to jump
Demonstration video.MP4
BOM download
PCB_PCB_Relay module_2022-09-24.pdf
PCB_PCB_Relay module_2022-09-24.json
PCB_Relay module_2022-09-24.pcbdoc
Gerber_PCB_Relay module_2022-09-24.zip
Schematic_Relay Module_2022-09-24.pdf
SCH_relay module_2022-09-24.json
61271
ad0831 convert 5v voltmeter
Introduction: STC89C52RC microcontroller and adc0831 5v voltmeter
For the stc89c52rc microcontroller and adc0831 5v voltmeter, it is recommended to use the chip base. You can use the RXD and TXD serial ports to download the burning program. The ad.c in the attachment is the program. I couldn't find the voltage display programs for STC89C52RC and ADC0831 before, but I finally found two. The damn library even deleted the pictures. How can we rest! The program has passed the test.
ad.c
BOM_PCB_ad conversion 5v voltmeter_2022-05-12.csv
BOM download
PCB_PCB_ad conversion 5v voltmeter_2022-09-24.pdf
PCB_PCB_ad conversion 5v voltmeter_2022-09-24.json
PCB_ad conversion 5v voltmeter_2022-09-24.pcbdoc
Gerber_PCB_adconvert 5v voltmeter.zip
Schematic_ad0831 conversion 5v voltmeter_2022-09-24.pdf
SCH_ad0831 Convert 5v voltmeter_2022-09-24.json
61272
[Internet of Things] Hongmeng-wifi switch
Introduction: Use HI3861 chip to realize switch remote control
Practical HI3861 chip realizes switch remote control
VID_20220316_101330.mp4
BOM download
PCB_PCB_[Internet of Things] Hongmeng-wifi switch_2022-09-24.pdf
PCB_PCB_[Internet of Things] Hongmeng-wifi switch_2022-09-24.json
PCB_[Internet of Things] Hongmeng-wifi switch_2022-09-24.pcbdoc
Gerber_PCB_[Internet of Things] Hongmeng-wifi switch_2022-09-24.zip
Schematic_[Internet of Things] Hongmeng-wifi switch_2022-09-24.pdf
SCH_[Internet of Things] Hongmeng-wifi switch_2022-09-24.json
Hongmeng Smart Switch_SCH_2022-09-24.schdoc
61273
Mini_ODrive_F411_FD6288
Introduction: A streamlined version of ODrive
The simplified version of ODrive uses STM32F411/401 for the main control, FD6288 for the driver, and INA181 for current sampling. Compared with the original ODrive firmware, some castrations have been made, and the encoder linearization algorithm, dead zone compensation, and MT6816 encoder have been added. SPI mode support, optimized anti-cogging torque algorithm
61274
2021 Question C-Three-port DC-DC converter + waveform adjustment is not in line
Introduction: Electric Competition C Three-Port DC-DC Converter
### 一.前言
本设计实现了一个三端口DC-DC变换器,该变换器由两个双向DCDC变换器(分别称为主、副DCDC)、级联辅助转换器、锂电池、单片机和一系列电压/电流传感器组成。主DCDC和转换器的输入端在光伏电池输入端口并联,辅助转换器从模拟光伏电池转换12V和5V直流稳压为单片机和驱动芯片供电,锂电池接入副DCDC,主、副DCDC输出端并联入输出端口。单片机控制副DCDC,利用锂电池电压的相对稳定性,形成输出电压闭环回路,在输出端口维持30V的恒压;同时,单片机控制主DCDC,利用副DCDC产生的输出恒压,精确控制Ui,对其进行扰动以追踪最大功率点。模拟光伏电池为整个电路供电,当其最大输出功率不足以维持输出端口为30V时,电池组将同时为负载供电(模式II),此时IB≤ 0;当模拟光伏电池足以供电时,它还会给电池组充电(模式I),此时IB≥0。
### 二.项目分析
设计并制作三端口 DC-DC 变换器,其结构框图如图 1 所示。变换器有两种工作模式:模式 I,模拟光伏电池向负载供电的同时为电池组充电(IB≥0);模式 II,模拟光伏电池和电池组同时为负载供电(IB≤ 0)。根据模拟光照(US 的 大小)和负载情况,变换器可以工作在模式 I或模式 II,并可实现工作模式的自动转换,在各种情况下均应保证输出电压 UO稳定在 30V。
1. 基本要求
(1)US=50V、IO=1.2A 条件下,变换器工作在模式 I,UO=30V±0.1V,IB≥0.1A。
(2)IO=1.2A、US由 45V 增加至 55V ,电压调整率 SU ≤ 0.5% 。
(3)US=50V、IO由 1.2A 减小至 0.6A,负载调整率 SI ≤ 0.5%。
(4)US=50V、IO=1.2A 条件下,变换器效率≥90%。
2. 发挥部分
(1)IO=1.2A、US 由 55V 减小至 25V,要求:变换器能够从模式 I 自动转换到模式 II;在 US全范围实现最大功率点跟踪,偏差 ≤0.1V;电压调整率 SU ≤0.1%。
(2)US=35V、 IO=1.2A 条件下,变换器工作在模式 II,UO=30V±0.1V,效率≥95%。
(3)US=35V、 IO由 1.2A 减小至 0.6A,变换器能够从模式 II 自动转换到模式 I,负载调整率 SI ≤ 0.1%。
(4)其他。
3.说明
(1)图 1 中直流稳压电源、二极管 D、电阻 RS 构成模拟光伏电池。直流稳压电源建议使用输出电压不小于 60V(可两路串联获得),额定电流不小于 3A 的成品电源,使用过程中应注意安全、避免触电伤害,测试时直流稳压电源由赛区提供;二极管 D、电阻 RS的选用应注意电流、功率等指标,必要时加装散热装置,注意避免烫伤。
(2)图 1 中电池组由 4 节容量 2000~3000mAh 的 18650 型锂离子电池串联组成,要求采用自带管理功能(或自带保护板)的电池。电池组不需封装在作品内,测试时自行携带至测试场地,测试过程中不允许更换电池。
(3)参赛队应认真阅读所用电池的技术资料,能够正确估算或检测电池的荷电状态,测试前自行合理设定电池的初始状态,保证测试过程中电池能正常充、放电。
(4)制作时应合理设置测试点,具体可参考下图。
![image.png]
5.题目分析
拿到这个题目一开始,我们对这个系统得整体框架其实是模糊的。通过对这个题目要求进行分析,我们最终明确了这道题目的方案,先通过电阻分压将输入的电压降低,经过DC-DC升压后,调节输入输出符合题目要求比例,同时通过另一块双向DC-DC降压后为电池充电并稳定负载电压符合题目要求。当输入电压降低至一定值时,由于boost输入跟随为最大功率点无法为负载提供30v电压,此时通过电池后双向DC-DC电路调节并稳定负载电压至30v。该系统的模式切换由硬件闭环控制无需软件过多干涉。
![image.png]
### 三.硬件设计
1.系统的主功率电路为两个双向DC-DC变换器电路,如图所示。模式一下直流源输入后,经电阻分压作为一个boost的输入,调节PWM使得此板输入跟踪最大功率电且为电阻与电池同时供电。并联的buck电路降压实现对电池充电及对负载电压的调整。模式下二下电池经boost产生稳定30v为电阻供电,通过另一块boost控制保证Ui最大功率跟踪
![image.png]
![image.png]
2.输出电压及电流检测电路如图所示。电压检测选取电阻分压后经过运放制作电压跟随器达到相对稳定后进行数字滤波。电流采样选取INA282芯片放大信号,同时在输出端设计RC滤波器及电压跟随器稳压。
![image.png]
3.辅助电源我们采用tps5430和tps54360进行供电。由于题目要求所有电均从U1处取得,所以我们先采用高耐压芯片TPS5430进行取电并使输出稳定在12V,为驱动芯片IR2104和TPS54360供电。TPS54360将12V输入稳定在5V为单片机供电。
![image.png]
![image.png]
![image.png]
![image.png]
### 四.软件设计
1.控制程序的原理如图所示,分为两个相对独立的闭环控制,主DCDC所在的主回路由MPPT根据功率检测值给出Ui参考值,然后通过一个PID反馈回路保证主DCDC的输入端口电压,即Ui跟随该参考值。副DCDC则保持恒定的30V输出参考电压,同样通过一个PID反馈回路控制输出值Uo稳定在30V。
![image.png]
2.最大功率跟随(MPPT)程序的设计
本程序采用扰动观察法(爬山法)。当输出电压稳定在30V后,MPPT轻微改变Ui的参考值,随后Ui将跟随该值,待其稳定后,MPPT根据功率变化,如果功率增大,则继续向该方向改变Ui参考值,否则回退,并以更小的程度反向改变Ui。如此反复,当输入电压变化时,功率也会较大变化,从而再次放大扰动程度,实现长期跟随。
部分程序如下,所有代码已打包作为附件
void pid_control(double ui, double uo) //输入采样电压,改变输出的pwm波占空比
pidm.err_sum -= pidm.err[pid_cnt];
pidm.err[pid_cnt] = pidm.ExpectedVolt - ui;
pidm.err_sum += pidm.err[pid_cnt];
if((uo-30.0)<0.1 || (30.0-uo)<0.1){
pidm.OutCycle += (pidm.Kp*pidm.err[pid_cnt]+ pidm.Ki*pidm.err_sum);
if(pidm.OutCycle > 0.95){
pidm.OutCycle = 0.95;
if(pidm.OutCycle < 0.3){
pidm.OutCycle = 0.3;
duty_set(3, 1, pidm.OutCycle);
pids.err_sum -= pids.err[pid_cnt];
pids.err[pid_cnt] = pids.ExpectedVolt - uo;
pids.err_sum += pids.err[pid_cnt];
out_volt += pids.Kp*pids.err[pid_cnt]+ pids.Ki*pids.err_sum;
if(out_volt < 15){
out_volt = 15;
if(out_volt > 40){
out_volt = 40;
pids.OutCycle =BATTERY_VOLT/out_volt; //下管开通时间,与输出电压成正比
duty_set(3, 2, pids.OutCycle);
pid_cnt++;
if(pid_cnt == 10){
pid_cnt = 0;
### 五.实物展示
![image.png]
### 六.总结
这次电赛我们三人还是缺乏经验,遇到很多问题时候犹犹豫豫浪费了不少时间。好在最后也在规定的时间内完成时绝大部分题目要求,同时由于部分地方不够细致,导致我们最后一天发现其中一个测试点不符合题意,紧急调整拟合曲线。专业课上虽然也学到了一些开关电源相关知识,但实际应用中缺总能发现种种问题。从PCB设计,到选型,到实物制作于调试,每一步都有不少注意点。理论固然重要,但工科缺乏实践,确实与理论相距甚远。同时团队协作也保证了我们这次得以高效完成题目,这是我第一个开源的项目,旨在与喜爱电力电子的朋友们分享自己的制作经历与成果,以便共同成长。
b站展示视频链接如下
https://b23.tv/fNlqDza
设计报告.docx
programs.rar
video.mp4
BOM下载
PCB_PCB_dcdc__2022-09-24.pdf
PCB_PCB_dcdc__2022-09-24.json
PCB_dcdc__2022-09-24.pcbdoc
Gerber_PCB_dcdc__2022-09-24.zip
PCB_PCB_PCB_tps5430 12V_2021-12-10_2022-09-24.pdf
PCB_PCB_PCB_tps5430 12V_2021-12-10_2022-09-24.json
PCB_PCB_tps5430 12V_2021-12-10_2022-09-24.pcbdoc
Gerber_PCB_PCB_tps5430 12V_2021-12-10_2022-09-24.zip
PCB_PCB_1-PCB_PCB_TPS54560 copy_2021-12-10_2022-09-24.pdf
PCB_PCB_1-PCB_PCB_TPS54560 copy_2021-12-10_2022-09-24.json
PCB_1-PCB_PCB_TPS54560 copy_2021-12-10_2022-09-24.pcbdoc
Gerber_PCB_1-PCB_PCB_TPS54560 copy_2021-12-10_2022-09-24.zip
Schematic_2021年C题-三端口DC-DC变换器+波形调不队_2022-09-24.pdf
SCH_2021年C题-三端口DC-DC变换器+波形调不队_2022-09-24.json
2021年C题-三端口DC-DC变换器+波形调不队_2022-09-24.zip
61275
ip2161快充协议验证降压验证板
简介:ip2161快充协议验证降压验证板
Note: Don’t believe it or not in the BOM, all parameters are marked in the circuit diagram, and most of the chip components are in 0603 specifications.
This circuit uses STI34710 step-down and IP2161 fast charge protocol chip to make a fast charge protocol verification board.
The fast charge protocol supports QC3.0/QC2.0/FCP/AFC/Apple2.4A/BC1.2
because STI3471 limits the input voltage. Do not exceed 18V. , FU is a fuse that can be changed accordingly according to different input voltages. Since there is no 2A fuse, I directly short-circuited it to 0 ohm in the finished test product.
STI3471 output voltage calculation formula Vo=0.6*[1+(RA/RB)]
The default output of the charging circuit is 5V. According to the IP2161 manual, the recommended RA is 100K. Substituting into the calculation, we can get
RA=R3=100K RB=13.6K and the output is 5.01V because If there is no 13.6K resistor, R4 and R5 can be connected in series with two 6.8K resistors to get 13.6K.
IP2161 can set the maximum requested voltage during fast charging. To ensure flexibility, two 0603 resistor bits R7 and R8 are provided as jumpers.
R7 is short-circuited and the maximum requested voltage is 12V; R8 is short-circuited and the maximum requested voltage is 5V; both are not connected and the maximum requested voltage is 9V; remember Don't accept it all and we won't be responsible for any problems! ! !
It is recommended to choose 25v 220uF for the two input and output filter capacitors C1 and C4, which can be changed as needed.
The function of D1 here is to add a fast charging indicator light. It is recommended to use a 5.1V or 4.7V Zener diode for better effect. If different colors of LED lights are used, the lighting voltage will be different.
As shown in the figure, some parameters are different due to material reasons. Among them, I only have a 5.6V D1 Zener diode. In actual measurement, when the voltage is 6.6V, the LED lights up slightly.
If you can't find an input and output filter capacitor that is small in size and has enough voltage resistance, you can temporarily use 16V220UF instead. It won't be a problem. Just don't let the input voltage exceed the capacitor's voltage resistance.
I didn't pick up the highest requested voltage option for IP2161. POWER-Z actually recognized that it supports QC2.0-12V. I don't know why. Hahahaha. If you need to support 12V, remember to short-circuit R7 and the input voltage is higher than 12.6V. That’s it. Please add a ↓ B station video
requesting QC3.0 and attach it after the recording is completed and reviewed.
BOM download
PCB_ip2161 fast charge protocol verification buck verification board_2022-09-24.pdf
PCB_ip2161 fast charge protocol verification buck verification board_2022-09-24.json
ip2161 fast charge protocol verification buck verification board_2022-09-24.pcbdoc
Gerber_ip2161 fast charge protocol verification buck verification board.zip
Schematic_ip2161 fast charge protocol verification buck verification board_2022-09-24.pdf
SCH_ip2161 fast charge protocol verification buck verification board_2022-09-24.json
ip2161 fast charging protocol test_2022-09-24.schdoc
61276
PlotClock
Introduction: This project is a practice project to participate in the 2022 Lichuang EDA Bionic Robot Dog Training Camp;
it uses the PlotClock of the open source Hongmeng OpenHarmony system;
the structure is 3D printed, and the position of the pen clip is incorrectly designed, so it cannot fit a regular pen. Room for improvement;
2022 Lichuang EDA Bionic Robot Dog Training Camp Project Hardware (drawn using Lichuang EDA Professional Edition) Main Controller: Huawei Hongmeng Hi3861 Servo Driver Chip: PCA9685, using IIC interface communication, can drive all IOs and IIC of 16-channel servos at the same time The expansion interface, expansion power interface, etc. have all been introduced. Later, it can be used as an evaluation board and built for Linux using the software development environment. Reference: https://robot.czxy.com/ohos/day04/harmony_linux_env.html Based on genkipi, the structural parts are developed. 3D printing, please see the attachment for the part printing file reference: https://www.thingiverse.com/thing:248009 3D structure coloring diagram:image.png
PlotClock demonstration video.mp4
PlotClock-3D printed parts.zip
PCB.mp4
61277
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 20:11:53
  • Detailed discussion on LED sorting, light separation, color separation, etc.
  • Graduation project topic
  • C const usage
  • I want the source code of the microcontroller angle measurement. I beg you!!!
  • Does samba configuration require a network?
  • Keil's MDK5.20A is missing files
