super_star
loli loli loli 8 channel reception
Loli 3rd generation 8 channel receiving firmware.hex
BOM download
PCB_PCB_loli Loli Loli 8-channel reception_2022-09-24.pdf
PCB_PCB_loli Loli Loli 8-channel reception_2022-09-24.json
PCB_loli Loli 8-channel reception_2022-09-24.pcbdoc
Gerber_PCB_loli Loli Loli 8-channel reception.zip
Schematic_loli Loli Loli 8-channel reception_2022-09-24.pdf
SCH_loli Loli Loli 8-channel reception_2022-09-24.json
Sheet_1_2022-09-24.schdoc
61444
【RA】Classic Snake based on R7FA2E1A72DFL
Introduction: Classic Snake based on R7FA2E1A72DFL
Based on the Renesas R7FA2E1A72DFL chip, using a few tact switches and a screen, we plan to reproduce the classic Snake game~IMG_20220724_152935.jpg
BOM download
PCB_PCB-[RA] OLED screen based on R7FA2E1A72DFL_2022-09-24.pdf
PCB_PCB-[RA] OLED screen based on R7FA2E1A72DFL_2022-09-24.json
PCB-[RA] OLED screen based on R7FA2E1A72DFL_2022-09-24.pcbdoc
Gerber_PCB-[RA] OLED screen based on R7FA2E1A72DFL.zip
Schematic_[RA] Classic Snake based on R7FA2E1A72DFL_2022-09-24.pdf
SCH_[RA] Classic Snake based on R7FA2E1A72DFL_2022-09-24.json
SCH-[RA] OLED screen based on R7FA2E1A72DFL_2022-09-24.schdoc
61445
SY7304 DC-DC4A boost adjustable module
Introduction: Modified from https://oshwhub.com/wzw666/LD701_DC7304LKJ_ADJ by user Ismartware Zhirong
Input voltage: 4.5-9V
Output voltage: 5-33V
The maximum input current does not exceed 4A, and pay attention to heat dissipation measures.
The EN switch control module works as
a pure boost circuit, and the output voltage must not be lower than the input voltage.
Modified from the user Ismartware. https://oshwhub.com/wzw666/LD701_DC7304LKJ_ADJ
BOM download
PCB_PCB_SY7304_2022-09-24.pdf
PCB_PCB_SY7304_2022-09-24.json
PCB_SY7304_2022-09-24.pcbdoc
Gerber_PCB_SY7304_2022-09-24.zip
Schematic_SY7304 DC-DC4A boost adjustable module_2022-09-24.pdf
SCH_SY7304 DC-DC4A boost adjustable module_2022-09-24.json
Sheet_V1_2022-09-24.schdoc
61446
CIG25-1605N VFD1602 display module
Introduction: CIG25-1605N VFD1602 display module
# EEI TECHNOLOGY 05P-FLUORITE Series CIG25-1605N VFD 16x2 character VFD display module
* **Has a wide voltage input range of 4.5-15V. **
* **Adaptive 3.3V/5V level (compatible with 51, STM32 and other mainstream microcontrollers). **
* **Improved power supply and filament driving scheme, no whistling and more efficient. **
* **The VFD screen has a built-in timing controller, which effectively avoids screen burn-in caused by improper use. **
* **1024 levels of brightness adjustable. **
* **SPI communication only requires 5 wires to drive. **
* **Ultra-low power consumption, the maximum power consumption is about 0.8W (full lighting, 1024 brightness, 5V input). **
* ** Built-in ASCII font library, you only need to send instructions to the screen to complete the display. **
* **89x37mm ultra-small size**
## Copyright Statement
* **The copyright of this project belongs to EEI TECHNOLOGY electronic studio. **
* **This project is under the CC-BY-NC-SA license (i.e. Creative Commons-Attribution-Noncommercial-Share Alike) and unauthorized deductions (interception of parts of the original project or modifications based on the original project) are prohibited The new project that is born is called "deduction"). Even if it is authorized, the project must be shared in the same way before it can be deduced (the signature and source of the original author need to be marked). If you ignore the open source agreement and conduct commercial activities, this work will The office will hold them accountable and crack down severely! Please consciously abide by the open source agreement and jointly maintain the open source environment. **
* **This project is for DIY and learning purposes only. It is prohibited to use this project for any commercial activities (sales, dissemination, copying for profit), including but not limited to the above three points. **
* **In order to prevent some merchants from speculating on the screen, I have controlled the display screen of this project and sold it at a normal price. Please forgive me! **
## Display purchase link
* **Note: Because this screen is not produced in large quantities and is new, the price is a bit expensive. **
* **[Click here to purchase](https://item.taobao.com/item.htm?id=672570251161)**
## Finished product picture
![image.png] ![image.png]
## Display effect display
CIG25-1605N font changes.pdf
BOM download
PCB_EPC-INBN0BV1605UD_2022-09-24.pdf
PCB_EPC-INBN0BV1605UD_2022-09-24.json
EPC-INBN0BV1605UD_2022-09-24.pcbdoc
Gerber_EPC-INBN0BV1605UD.zip
Schematic_CIG25-1605N VFD1602 display module_2022-09-24.pdf
SCH_CIG25-1605N VFD1602 display module_2022-09-24.json
EPC-INBN0BV1605UD_2022-09-24.schdoc
61447
GP1287BI VFD display module (UNL-200AP)
Introduction: UNL-200AP universal VFD display module
#EEI TECHNOLOGY 05P-FLUORITE UNL-200AP Universal VFD display module
* **Has a wide voltage input range of 4.5-20V. **
* **The maximum power consumption is about 6W (full lighting, 1024 brightness, 5V input). **
* ** Built-in dynamic scanning logic and RAM, you only need to send instructions to the screen to complete the display. **
* **Reserve the main control board position on the PCB to effectively utilize the free space. **
* **The audio input interface is reserved to facilitate audio applications. **
* **Onboard photoresistor, with microcontroller, can achieve automatic brightness. **
* **TYPEC and DC005 power interface, suitable for various power supplies. **
## Precautions
* **The driver board has high voltage, please operate with caution. **
* ** U8G2 project (STM32CubeIDE) is provided. Due to my poor programming skills, I cannot develop other drivers. If necessary, please develop it yourself. **
* **U8G2 project pin description: PA5 SCK, PA7 SDA, PA1 CS, PA3 RESET**
* **[Data link](https://pan.baidu.com/s/1Wrj8wwwIpFY7kO-CtEar5g) Extraction code n6ix**
## VFD purchase link (optional purchase of screen alone or screen + driver board)
* **[Click here to purchase](https://item.taobao.com/item.htm?id=667269822288)**
# # The front of the board
![image.png]
## The back of the board
![image.png]
## Display the rendering
![image.png]
![image.png]
BOM download
PCB_EPC-INBN0BV1287UD_FK_2022-09-24.pdf
PCB_EPC-INBN0BV1287UD_FK_2022-09-24.json
EPC-INBN0BV1287UD_FK_2022-09-24.pcbdoc
Gerber_EPC-INBN0BV1287UD_FK_2022-09-24.zip
PCB_EPC-INBN0BV1287UD_BK_2022-09-24.pdf
PCB_EPC-INBN0BV1287UD_BK_2022-09-24.json
EPC-INBN0BV1287UD_BK_2022-09-24.pcbdoc
Gerber_EPC-INBN0BV1287UD_BK_2022-09-24.zip
PCB_EPC-INBN0BV1287UD_2022-09-24.pdf
PCB_EPC-INBN0BV1287UD_2022-09-24.json
EPC-INBN0BV1287UD_2022-09-24.pcbdoc
Gerber_EPC-INBN0BV1287UD.zip
Schematic_GP1287BI VFD display module (UNL-200AP)_2022-09-24.pdf
SCH_GP1287BI VFD display module (UNL-200AP)_2022-09-24.json
EPC-INBM0BV1287UD_2022-09-24.schdoc
61448
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 07:20:19
