aerobotics
The most beggar 61+3 keyboard (10cm spliced ​​version)
The motherboard is made up of three PCBs within 10x10cm. Due to the modification of the LED driver circuit, it is necessary to burn the exclusive firmware of the accessory. Note that the LED can be welded forward and backward, and will be divided into two groups. The rest of the instructions refer to the original project to assist the developer. The 3D printed shell has not been verified yet, so stay tuned~QQ picture 20220802213018.jpg
Beggar 61 lock brightness version.hex
Three-piece bottom plate printing file-with edge.zip
Two pieces of 3D printed bottom plate - without edge wrapping.zip
BOM download
PCB_61 keyboard low cost (C board) copy_2022-09-23.pdf
PCB_61 keyboard low cost (C board) copy_2022-09-23.json
61 keyboard low cost (C board) copy_2022-09-23.pcbdoc
Gerber_61 keyboard low cost (C board) copy.zip
PCB_positioning board (A board)_2022-09-23.pdf
PCB_positioning board (A board)_2022-09-23.json
Positioning board (A board)_2022-09-23.pcbdoc
Gerber_positioning board (A board)_2022-09-23.zip
PCB_Bottom (C board)_2022-09-23.pdf
PCB_Bottom (C board)_2022-09-23.json
Bottom board (C board)_2022-09-23.pcbdoc
Gerber_Bottom (C board)_2022-09-23.zip
PCB_Bottom (B board)_2022-09-23.pdf
PCB_Bottom (B board)_2022-09-23.json
Bottom board (B board)_2022-09-23.pcbdoc
Gerber_Bottom (B board)_2022-09-23.zip
PCB_positioning board (B board)_2022-09-23.pdf
PCB_positioning board (B board)_2022-09-23.json
Positioning board (B board)_2022-09-23.pcbdoc
Gerber_positioning board (B board)_2022-09-23.zip
PCB_Bottom (A board)_2022-09-23.pdf
PCB_Bottom (A board)_2022-09-23.json
Base plate (A board)_2022-09-23.pcbdoc
Gerber_Bottom (A board)_2022-09-23.zip
PCB_61 keyboard low cost (C board)_2022-09-23.pdf
PCB_61 keyboard low cost (C board)_2022-09-23.json
61 keyboard low cost (C board)_2022-09-23.pcbdoc
Gerber_61 keyboard low cost (C board).zip
PCB_61 keyboard low cost (B board)_2022-09-23.pdf
PCB_61 keyboard low cost (B board)_2022-09-23.json
61 keyboard low cost (B board)_2022-09-23.pcbdoc
Gerber_61 keyboard low cost (B board).zip
PCB_61 keyboard low cost (A board)_2022-09-23.pdf
PCB_61 keyboard low cost (A board)_2022-09-23.json
61 keyboard low cost (A board)_2022-09-23.pcbdoc
Gerber_61 keyboard low cost (A board).zip
PCB_61 keyboard low cost (adding connection pads)_2022-09-23.pdf
PCB_61 keyboard low cost (add connection pad)_2022-09-23.json
PCB_61 keyboard low-cost version_2022-09-23.pdf
PCB_61 keyboard low-cost version_2022-09-23.json
Schematic_The most beggar 61+3 keyboard (10cm spliced ​​version)_2022-09-23.pdf
SCH_The most beggar 61+3 keyboard (10cm spliced ​​version)_2022-09-23.json
The most beggar 61+3 keyboard (10cm spliced ​​version)_2022-09-23.zip
61 keyboard low-cost version_2022-09-23.pcbdoc
Gerber_61 keyboard low-cost version.zip
61 keyboard low cost (adding connection pad)_2022-09-23.pcbdoc
Gerber_61 keyboard low cost (add connection pad).zip
61683
[Spark Project] The most beggar 17+4+ touch mechanical keyboard PRO
Introduction: The orthodox sequel to the most beggar's touch numeric keyboard, this time the code will be open sourced for the first time.
Don't say that you, the author, don't follow martial ethics. I just created your old project and you updated it.
The functionality and practicality completely surpass the previous version. Moreover, it was published one and a half years apart
Regarding the content, the following description is not all of this keyboard. There is also a sister project "The Most Beggar 68+4 Mechanical Keyboard PRO". It is better to use the two together.
Coincidentally, the two competitions are now being held at the same time, so the two projects are pitched on different tracks. In order not to repeat the content, the emphasis is different.
Spark Project’s Station B entry video:
https://space.bilibili.com/555199816/channel/series Remember to comment three times in a row. Only when you win will you be motivated to keep updating. Thank you everyone! ! !
Collection of authorized sales:
[Tencent Documents] Authorization ID and authorization fee accounting for beggar’s small keyboard https://docs.qq.com/sheet/DSXd2bm5rdVh2aHVk
Preface
To be honest, the most popular among my open source projects is the small keyboard project , because of its low cost and unique touch bar functions, many people do it.
Of course, the high number of views may also be related to the keyboard macro automatically opening the open source URL. The original intention is to facilitate everyone to browse the instructions and emphasize the open source nature of the project. There is no malicious intent to increase the number of views!
While interacting with readers, I saw all kinds of people. Some of them regarded welding as much fun as building a Gundam. They even thought that my project required less welding and asked me to make it more difficult.
Some people don't read the instructions and hope that the layout will omit the prominent part. After explaining that this is a touch bar, I sighed, "The function is so NB, only for this price."
I have also seen students who are not majoring in electricity buy a soldering iron for the first time for this project. Ask me to recommend soldering tools.
There was even an uncle with a baby who took out a soldering iron that had been sealed for a long time and started soldering. (It’s true that seniority is called that, but people who play with electronics are not convinced by their seniority. They may think that picking up a soldering iron will bring them back to their school days.
17-key RGB keyboard program V10.hex
17-key RGB keyboard program Ver1.0 (open source version).zip
The most beggar 17-key PRO_T_V1.1.hex
Beggar 17+4TPRO_Ver120.hex
Beggar 17+4TPRO_Ver121.hex
Beggar 17+4TPRO_Ver122.hex
PDF_[Spark Project] The most beggar 17+4+ touch mechanical keyboard PRO_2022-11-05.zip
BOM_Baseboard_Baseboard PCB_2022-11-05.xlsx
Altium_[Spark Project] The most beggar 17+4+ touch mechanical keyboard PRO_2022-11-05.zip
PCB_Bottom PCB_2022-11-05.pdf
61684
#十三级电竞# The most beggar 68+4 mechanical keyboard PRO
Introduction: An upgrade based on my old project "The Most Beggar 61+3 Mechanical Keyboard".
The layout was modified, the HUB planned to be added from the beginning was added, the keyboard backlight was changed to RGB, and OpenRGB was connected.
If the competition ends, please jump to the open source platform to view the latest version. When the competition ends, the score locking project will be carried out. This layout will then become uneditable. The GaiZhongGai-Keyboard-68+4PRO - EasyEDA open source hardware lab (oshwlab.com) also has an English version for communicating with foreign friends. Regarding the content, the following description is not all of this keyboard. There is also a sister project "The Most Beggar 17+4+ Touch Mechanical Keyboard PRO", it is better to use the two together. Coincidentally, the two competitions are now being held at the same time, so the two projects are pitched on different tracks. In order not to repeat the content, the emphasis is different. Preface Many readers who are not in the computer installation circle may not understand the meaning of this beggar's beggar. This word is more commonly used on computer motherboard graphics cards. It refers to the beggar’s edition among beggars’ editions, the low-profile among low-profile, the shrinkage among shrinkage, which is homophonic to the former CCTV advertisement. And I’m not using it as a project name for sales promotion, so there’s no problem. The benefits of low configuration are obvious, that is, the cost is low, and students love it most. We all have experienced spending money on electronics, but as teachers, I hope you will not cut back or even skip meals when budgeting for living expenses. You can find a classmate AA, or use extra PCB assembly to hang idle fish to recover health (investment is risky!!!), but remember to comply with the open source agreement. Here is a comparison table of commonly used microcontroller configurations with QMK solutions: model STM32F103C8T6GD32F103C8T6ATMEGA32U4-AUCH551 G Lichuang number C8734C77994C44854C108958 single price (June 24, 2022) ¥42.58¥14.35¥129.92¥ 2.69 package LQFP-48LQFP-48QFP-44SOP-16I/O number 37372612.5 (RST pin can only be read, when half) digits 32-Bit32-Bit8-Bit8-Bit core ARM® Cortex®-M3ARM® Cortex®-M3AVRC51ROM64kB64kB32kB10kBRAM20kB20kB2.5kB0.75kBEEPROM None (but can be simulated with FLASH) None (but can be simulated with FLASH) Can use FLASH simulation) 1kB128B comparison shows that the configuration difference is not big, the main reason is that there is no ecology. When the keyboard was first released as open source, I planned to open source the code, but I felt that it was not popular enough and I was afraid that someone would use it for profit and delete the original author information. However, the "core shortage" caused the price of the above microcontrollers to rise, and the popularity of my project also increased. Moreover, there is also the spiritual and material support of loyal fans, who help communicate with Xianyu sellers to add open source tags, and reward the author with a fixed amount after the sales proceeds. With such support, can you update diligently? Thank you for your support along the way~ 1. The project function introduction is based on the upgrade of my old project "The Most Beggar 61+3 Mechanical Keyboard". To satisfy my original need for a keyboard with a hub, since there was no room for a third USB socket, I placed an SD card reader under the space. The configuration has been modified, the keyboard backlight has been changed to RGB, and OpenRGB has been connected. And Chinese support has been added to the project. With the poor peripherals of CH551G, a lot of optimizations have been made to meet the strict timing requirements of WS2812. Normal statekeyboard-layout.png
The most beggar 68-key RGB keyboard program V10 open source.hex
68 keyboard program Ver1.00 (open source version).zip
OpenRGB Chinese.zip
studio_video_1659892762090 [720p].mp4
VID_20220607_210912~1.mp4
BOM download
PCB_68+4+HUB+SD lower lamp position_2022-09-23.pdf
PCB_68+4+HUB+SD lower light position_2022-09-23.json
68+4+HUB+SD lower lamp position_2022-09-23.pcbdoc
Gerber_68+4+HUB+SD lower light position.zip
PCB_68+4 positioning board_2022-09-23.pdf
PCB_68+4 positioning board_2022-09-23.json
68+4 positioning board_2022-09-23.pcbdoc
Gerber_68+4 positioning plate_2022-09-23.zip
PCB_68+4 base plate (lower lamp wiring pattern)_2022-09-23.pdf
PCB_68+4 base plate (lower lamp wiring pattern)_2022-09-23.json
68+4 base plate (lower lamp wiring pattern)_2022-09-23.pcbdoc
Gerber_68+4 base plate (lower lamp wiring pattern)_2022-09-23.zip
PCB_68+4+HUB+SD upper lamp position_2022-09-23.pdf
PCB_68+4+HUB+SD upper lamp position_2022-09-23.json
68+4+HUB+SD upper lamp position_2022-09-23.pcbdoc
Gerber_68+4+HUB+SD upper lamp position.zip
Schematic_#The 7th Lichuang Electric Competition#The most beggar 68+4 mechanical keyboard PRO_2022-09-23.pdf
SCH_#The 7th Lichuang Electric Competition#The most beggar 68+4 mechanical keyboard PRO_2022-09-23.json
#十三级电竞# The most beggar 68+4 mechanical keyboard PRO_2022-09-23.zip
61685
Buck-boost power supply
Introduction: It meets some normal power supply needs. It is more convenient to hold when doing experiments. The power supply ripple is small and the driving ability is strong.
The main purpose is to use two DC-DC modules to save voltage and reduce the cost.
BOM download
PCB_PCB_Boost and buck power supply_2022-09-23.pdf
PCB_PCB_Boost and buck power supply_2022-09-23.json
PCB_Boost and buck power supply_2022-09-23.pcbdoc
Gerber_PCB_Boost and buck power supply.zip
Schematic_Boost and buck power supply_2022-09-23.pdf
SCH_Boost and buck power supply_2022-09-23.json
Sheet_1_2022-09-23.schdoc
61686
BLHleli ESC
Introduction: Open source ESC
BLHleli ESC, brushless motor drive, ESC
is for reference only
Homemade open source ESC, BLHeli_S
reference production: https://oshwhub.com/CLZ1/ji-yublheli-diesc
The file is in the attachment, you can pick it up if you need it
The following are image display:
ESC front
back
Schematic diagram
PCB
BLS_hd.SchDoc
BLS_V1.1.PcbDoc
BOM download
61687
F411 flight control
Introduction: The STM32F411 flight control of the flying machine
uses matek firmware and supports betaflight and INAV.
Sensor: MPU6000+BMP280+QMC5883 Interface: PWM×6, uart×2, LED, buzzer, OSD, USB
Size: 30×30mm, mounting hole 20×20mm
Schematic 1
SensorPCB positivePCB reverse
Description:
1. The resistance detected by VBAT is 10K: 1K, There is no change in the schematic diagram, just solder 10 directly on the PCB.
2. After the test flight, the self-stabilization is very strong and the heading is very stable.
3. The BF firmware used is 3.5.7. After upgrading to a higher version, the magnetometer will not be able to detect it. (The manufacturer seems to have stopped producing the flight controller. It is probably because the subsequent firmware will not be maintained.)
4. There seems to be something wrong with the OSD. You can update the font. The OSD display in the Task list is also normal, but the image transmission cannot receive the picture. (I’ll work on it later, I’ll update it when it’s done...)
02_Sensor.SchDoc
MATEK_F411SE.PcbDoc
Bitmap MATEK_F411SE.pdf
Assembly drawing MATEK_F411SE.pdf
01_MCU&Power.SchDoc
betaflight_3.5.7_MATEKF411SE.hex
Hover test.mp4
BOM download
61688
Beidou module test HT1612
Introduction: Beidou test board, using HT1612, uses serial port (RX, TX) to interact with the host computer
As required by the course, the Beidou test board was produced. In the actual test, the signal can be found. In the antenna placement window, more than 5
four-layer boards of GPS and Beidou satellites can be found. The impedance matching line width is 32.61mil.
The Beidou module uses USB to ttl to connect to the serial port. The upper level The machine uses ustar, and it has been uploaded to the attachment.
When welding, the inductor package was not adjusted properly, and the pad appeared large, which does not affect the use. The battery package was drawn by myself. If you do not use the battery, you do not need to weld the BAT capacitor. The battery was originally designed for tire pressure battery welding. Use it, forget to design the charging circuit, and temporarily discard
the physical picture (the pins on the left are GND, TXD, RXD, and 5V from top to bottom, and forget to mark them in the picture):
PCB:
Schematic:
uSTAR.7z
BOM download
PCB_PCB_beidou_2022-09-23.pdf
PCB_PCB_beidou_2022-09-23.json
PCB_beidou_2022-09-23.pcbdoc
Gerber_PCB_beidou_2022-09-23.zip
Schematic_Beidou module test HT1612_2022-09-23.pdf
SCH_Beidou module test HT1612_2022-09-23.json
61689
(verified)BilClock
Introduction: A small TV made with a 0.96-inch OLED screen, which can display the time, number of fans of Station B and countdown.
This project is based on a small TV weather clock - you can optimize the PCB layout if you have the skills
. The firmware is from the original author. You can take a look at the original project.
Note: You can directly flash the original author's Bin file, and only the data folder in the uploaded code can display the network configuration web page.
The attachment contains bin and upload tools.
Features:
1. Use Type-C interface.
2. Use ME6211C33M5G-N LDO voltage regulator chip.
3. The charging chip uses TP4059.
4. The main control uses ESP-07S.
5. The display module uses 0.96-inch OLED.
PCB pictures:
Front
and back
finished product pictures:
FamilyMart:
Upload data distribution network interface
BilClock.zip
BOM download
PCB_PCB_BilClock_2022-09-23.pdf
PCB_PCB_BilClock_2022-09-23.json
PCB_BilClock_2022-09-23.pcbdoc
Gerber_PCB_BilClock_2022-09-23.zip
Schematic_(verified)BilClock_2022-09-23.pdf
SCH_(verified)BilClock_2022-09-23.json
PCB_BilClock_2022-09-23.schdoc
61690
electronic
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-04 04:02:17
