ohahaha
8838 Front and rear panels_GX12-F-5 through-wall aviation plug
 8838 front and rear panels + GX12-F-5-pin wall aviation plug.
The 5-pin wall aviation plug is not compatible with the 6-pin one! The 5-pin wall plug is not compatible with the 6-pin one! The 5-pin wall plug is not compatible with the 6-pin one!
1.T12 soldering station front panel, adapted to 8838 shell. For the following projects: Suzaku T12 soldering station
2. Only suitable for this 8838 shell: https://item.taobao.com/item.htm?spm=a1z09.2.0.0.3d712e8dYNNnYH&id=604087009395&_u=j6p063q484b
3. Used GX12- F-5-core through-wall aviation socket (easy to disassemble): https://item.taobao.com/item.htm?spm=a1z09.2.0.0.1c6a2e8dIILgHr&id=627942539887&_u=j6p063qcd45
4. Special statement: produced by each manufacturer The shell size is different, and others may not match. Please determine whether it is suitable, or please modify it before use. The links listed here have nothing to do with me and are for reference only.
5.
I forgot to select a color for the photo, so it was set to the default color green. White is recommended.
6. Reference materials:
        The PCB copper foil windows and solder mask windows used in this project are used to transmit LED light, which has a hazy aesthetic and does not require PCB drilling. This idea comes from the power amplifier project of the boss HACK, and I would like to thank him.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-25 15:09:30
