smallembedded
FEBFL77944-L80H012A-GEVB: 12 ​​W ACLED driver for downlights for high voltage lines
FEBFL77944-L80H012A-GEVB: 12 W Down Light ACLED Driver at High-Line
The FEBFL77944-L80H012A-GEVB is a direct AC line LED driver with a minimum number of external RC passive components. In normal configuration, one resistor is used to regulate the LED power and one capacitor is used to provide a stable voltage for the internal bias shunt regulator. The FEBFL77944-L80H012A-GEVB provides phase-cut dimming with a wide dimming range, smooth dimming control, and good dimmer compatibility. It achieves high efficiency, high PF, and low THD, which makes the FEBFL77944-L80H012A-GEVB suitable for high-efficiency LED lighting systems. The FEBFL77944-L80H012A-GEVB has a dedicated DIM pin that can be used for analog or digital PWM dimming. The FEBFL77944-L80H012A-GEVB can also be used with a rheostat dimming switch for desktop or indoor lamps. The high wattage design of the FEBFL77944-L80H012A-GEVB can be achieved by embedding multiple ICs in parallel, making it suitable for street lighting and downlight applications. Features & ApplicationsFeaturesPower scalability through multiple driver ICsFlexible LED forward voltage configurationSOP16 EP packageLow harmonic content (THD less than 20% in normal configuration)Adjustable LED power through external current sense resistorAnalog/digital PWM dimming capabilityHigh power factor (above 0.98 in normal configuration)Variator dimmableTRIAC dimmable (leading edge/trailing edge)Four integrated high-voltage LED constant current sources with up to 150 mA (RMS) capabilityWide AC input range: 90 ~ 305 VACSimplest direct AC LED driver, only two external RC passive componentsOver temperature protection (OTP)
The FEBFL77944-L80H012A-GEVB is a direct AC line LED driver with a minimal number of external RC passive components. In normal configuration, one resistor is to adjust LED power, and one capacitor is to provide a stable voltage to an internal biasing shunt regulator.
The FEBFL77944-L80H012A-GEVB provides phase-cut dimming with wide dimming range, smooth dimming control and good dimmer compatibility. It achieves the high efficiency with high PF and low THD which makes the FEBFL77944-L80H012A-GEVB suitable for high-efficiency LED lighting systems. The FEBFL77944-L80H012A-GEVB has dedicated DIM pin which can be used with analog or digital PWM dimming. The FEBFL77944-L80H012A-GEVB can also be used with a rheostat dimmer switch which is suitable for desktop or indoor lamps.
High wattage design of the FEBFL77944-L80H012A-GEVB can be implemented with multiple IC embedded in parallel for street lighting and down lighting applications.
Features and Applications
Power Scalability with Multiple Driver ICs
Flexible LED Forward Vol tag Configuration
SOP16 EP Package
Low Harmonic Content (THD under 20% in normal configuration)
Adjustable LED Power with an External Current Sense Resistor
Analog/digital PWM Dimming Function
High Power Factor (above 0.98 in normal configuration)
Rheostat Dimmable
TRIAC Dimmable (Leading/Trailing Edge)
Four Integrated High-Voltage LED Constant Current Sinks of up to 150 mA (RMS) Capability
Wide AC Input Range : 90~305 VAC
The simple st Direct AC LED Driver with Only Two External RC Passive Component
Over Temperature Protection (OTP)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 14:32:50
