桂花蒸
NCP382HD10AAGEVB: Single-input dual-output high-side power distribution switch evaluation board
NCP382HD10AAGEVB:  Single Input Dual Outputs High Side Power Distribution Switch Evaluation Board
The NCP382 is a single input dual outputs high side power distribution switch designed for applications where heavy capacitive loads and short circuits are likely to be encountered, incorporating two 80 mΩ, P-channel MOSFETs in a single package. The device limits the output current to a desired level by switching into a constant current mode when the output load exceeds the current limit threshold or a short is present. The current limit threshold is internally fixed. The power switches rise and fall times are controlled to minimize current ringing during switching. The FLAG logic output asserts low during overcurrent and over temperature conditions. The switch is controlled by a logic enable input active high or low.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-13 01:05:46
  • ads8317 reads out 0 all the time
  • Why doesn't this code work? Please help me, thanks!
  • Advanced Courseware for MCU Masters
  • keil
  • The EMI radiation of the switching power supply exceeds the standard. How to correct it?
  • Ask a question about welding
