红水杯
NCV706278FULLGEVK: LIN Automotive Stepper Motor Driver Kit
NCV706278FULLGEVK: LIN Automotive stepper motor driver kit
The plug-and-play NCV70627/8FULLGEVK LIN Automotive Stepper Motor Driver Kit is packaged in a plastic box for demonstration purposes only. It contains all the hardware and software required to control the NCV70627/NCV70628 micro-stepping motor drivers from a PC. A user-friendly graphical user interface (GUI) makes it easy to operate the evaluation kit. The provided mainboard provides a lot of flexibility in your development process. Easy access to multiple signals makes debugging very easy, and you can connect the evaluation kit with your own application, reducing development time. The separate daughter boards make it very easy to evaluate the entire NCV7062X family. Note: This kit can be used with the following orderable daughter boards: NCV70627: NV706272R2DBDQGEVB NV706272R2DBMWGEVBNCV70628: NV706281R2DBGEVB
The plug-and-play NCV70627/8FULLGEVK LIN Automotive Stepper Motor Driver Kit is delivered in plastic case and is intended for presentation purposes. It contains all necessary hardware and software needed to control the NCV70627/NCV70628
microstepping motor driver from your PC. The user-friendly Graphical User Interface (GUI) makes it possible to operate the evaluation kit in an easy way. Provided motherboard gives a lot of flexibility during your development process.
Easy access to several signals makes debugging very easy and gives you the possibility to connect the evaluation kit with your own application which reduces the development time. Evaluation of the complete NCV7062X family is made very
easy by means of the separate daughtersboards.
Note : This kit can be used with the following orderable daughterboards:
NCV70627:
NV706272R2DBDQGEVB
NV706272R2DBMWGEVB
NCV70628:
NV706281R2DBGEVB
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-10 16:10:23
