王达业
NIS5021MT1GEVB: +12 Volt Electronic Fuse
The NIS5021MT1GEVB Evaluation Board showcases a cost effective, resettable fuse which can greatly enhance the reliability of a hard drive or other circuit from both catastrophic and shutdown failures. The eFuse is designed to buffer the load device from excessive input voltage which can damage sensitive circuits. It includes an overvoltage clamp circuit that limits the output voltage during transients but does not shut the unit down, thereby allowing the load circuit to continue its operation. The eFuse also includes an internal Undervoltage Lockout Circuit as well as an Internal Charge Pump. The NIS5021MT1EVB evaluation board has many features which make it simple to observe the functionality and performance of NIS5x2x line of eFuses including multiple connectors available for all eFuse pins (VCC, GND, SRC, enable, ILIM, dv/dt), input and output capacitors, a pushbutton switch and a MOSFET to connect the enable pin to GND or float as needed, green and yellow LEDs to indicate whether the eFuse enable pin voltage is high (device enabled)/low (device disabled)/mid (thermal shutdown), 5 current limit resistor options available directly on the board (20, 25, 30, 35, 40 Ω), 4 load resistor options (200 Ω each) on the board, a jumper to short circuit the load, kelvin or direct sensing options via jumpers between pin 6 and 7 for NIS5x2x.
Features and Applications
14 mΩ, 24 mΩ & 44 mΩ Typical RDSON Options
Tristate Enable
Overcurrent Protection
Thermally Protected
Integrated Soft-Start Circuit
Fast Response Overvoltage Clamp Circuit
Servers
Hard Drives
Solid State Drives
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-02 08:51:00
