The RSL10 Sensor Development Kit is a compact and a comprehensive platform to easily develop IoT applications with leading sensor technology and the industry's lowest power Bluetooth ® Low Energy SoC.
The compact platform features a full range of sensors including environmental, inertial (3-axis accelerometer, 3-asix gyroscope and a low-power smart hub for motion sensing), a geomagnetic sensor, and an ambient light sensor. Example use cases and detailed documentation are provided in the CMSIS pack. In addition to monitoring the various sensor values, the accompanying mobile application (available on Google Play™, iOS®), connects to several cloud services (AWS, IBM®, Azure™) enabling a true end-to-end solution development.The RSL10 Sensor Development Kit is also available with an accompanying debugger (RSL10-SENSE-DB-GEVK (debug version).
Bluetooth IoT Development Kit CMSIS-Pack
The Bluetooth IoT Development Kit CMSIS-Pack includes several example application projects. These projects allow for rapid development of various Bluetooth Low Energy use-cases such as asset monitoring, asset tracking, wireless sensor networks, worker safety wearables, energy harvesting, etc. The application code can be used as-is on supported hardware or can be used as a building block in creating a more complex use case.
Veridify Security's Public Key Tools
Implement device-to-device security including authentication and data protection software for the RSL10 using Veridify's ISO 26262 ASIL D certified security tools.
SensiML Edge AI Software Package
Easily add low latency local AI predictive algorithms to industrial wearables, robotics, process control, or predictive maintenance applications regardless of expertise in data science and AI.
Features and Applications
Based on the RSL10 System-in-Package (SiP)
Bluetooth 5 certified
Certified to international wireless regulations (CE, IC, KC, MIC, FCC)
Configurable, low-power sensors
Ambient Light SensorBHI160 (Integrated low power smart hub, 3-axis accelerometer, 3-axis gyroscope) BMM150 (Low Power, Low Noise 3-axis digital geomagnetic sensor)BME680 (Integrated high-accuracy gas, pressure, humidity and temperature sensor) INMP522 (Ultra-low noise digital Microphone)APTF1616 (Programmable RGB LED)N24RF64 (64kB NFC EEPROM)3 programmable push-buttons
Supported by the RSL10 Sense and Control mobile app for cloud connectivity (Google Play™) (iOS®)
