fish001
0-30v 0-10A variable power supply with adjustable voltage and current
0-30v 0-10A Variable Power Supply Adjustable Voltage and Current
Variable power supply with voltage and current controls 1-30 Volts and 0-10A. Both voltage and current can be controlled by potentiometers, and multi-turn potentiometers facilitate high-precision settings. Output load should be less than 10 amps. And it requires a large radiator with a cooling fan for effective cooling. A DC voltammeter is also required to monitor the output. Components required: TIP3055 and BD139 Transistors LM7805 and LM317 Voltage regulator 10k, 220 ohm resistor + 1 LED 10k multi-turn potentiometer 2x 1N4007 diode 1x 5v DC cooling fan 1x DC voltmeter and ammeter
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-08 02:24:54
