蓝猫淘气
POGO ISP Micro: Small and reliable programming adapter for AVR ISP
POGO ISP Micro is a small and reliable programming adapter for AVR ISP. It requires a small ISP space on the PCB. It also has a reset button that allows you to simply reset the target device if you wish. The standard ISP port is too large. It has a pin pitch of 2.54mm, so it takes up a lot of space on the PCB. POGO ISP Micro Specs: 1.27 mm (0.05 in) pin pitch Reset button Power indicator light KiCAD library and footprint are ready for use on Github! Just drop it into your PCB design and you're ready to use POGO ISP Micro.
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-04 14:21:58
  • Battery applications in medical monitoring and the changing environment
  • Problems in measuring temperature, humidity and wind speed using MSP430F149
  • Extract LEF
  • This article may be useful for beginners
  • Mixed programming issues, hope everyone can give me some advice
  • Encoder signal input problem
