bb41F
LM75 temperature sensor module
This project is used to verify the solution verification board design of the temperature sensor LM75BD (product number C34565) of Lichuang Mall. Compatible with other SOIC-8_150mil packaged LM75 chips.
LM75B is a temperature sensor with a high-speed I2C interface that can directly convert temperature into a digital signal within the temperature range of -55°C to +125°C, and can achieve an accuracy of 0.125°C. The MCU can directly read the data in its internal registers through the I2C bus, and can operate the 4 data registers through I2C to set different working modes. LM75A has 3 optional logical address pins, allowing 8 devices to be connected to the same bus at the same time without address conflicts.
Features:
I2C bus interface, device address 7-bit slave address 1001xxx, 8 devices can be expanded on the same bus;
power supply range: 2.8V ~ 5.5V, temperature range: -55℃ ~ +125℃;
11-bit ADC provides temperature Resolution reaches 0.125℃;
temperature accuracy:
±2℃ (-25℃~100℃); ±3℃ (-55℃~125℃)
PCB:
![IMG_20200502_182626.jpg]
Test results:
![LM75_1.png]
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-12 09:03:02
