toothache
TM8211 Audio Stereo Digital-to-Analog Converter DAC Decoder Board
Demonstration video:
https://www.bilibili.com/video/BV1aa4y1u7x7/Introduction
   Most of the I2S decoding boards on Xbao are based on the PCM51XX series, with a price of more than 15, and the wiring is troublesome, and xmt needs to be set to a high level. The TM8211 decoding IC is less than 1 yuan, and the component cost of this decoding board is about 3-4 yuan. It is a dual-channel decoding board suitable for the ESP32 series development board, and the dual-channel FM8002D power amplifier circuit is integrated on the board. Through the switch key, two 1-2W small speakers can be directly driven. Of course, you can also use the audio cable directly without soldering the power amplifier circuit, connect it to the 3.5mm audio interface designed on the board, and play it with the speaker.
Update log:
    2023-5-10, design proofing, the first version
of LiChuang's PCB
soldered board
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 00:22:53
