oDI0a2YxO
10*10 adjustable power supply based on TL494
The board I drew a few years ago when I first started making PCBs for free has been running for about three and a half years after successful verification. Although it is not used a lot and the ripple has not been measured, it should not be small, but he did not blow up and brought it with him. Although the temperature control fan is not very good, when I was a freshman in high school, the circuit diagram was a mess. I didn’t know how to use the network terminal
30v10a, the isolation drive transformer 15+15+15, the main transformer primary 30 turns, the secondary 5+5, must follow the high The frequency transformer specification winding
temperature control fan part can be improved. Now the fan is in a start-stop working state
! [94eb3ed1d14474e032f71d5101aad25.jpg]
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 12:36:24
  • Design of soldering iron tip temperature control
  • Post an egg
  • AND
  • Use pressure sensor and ADC0809 to design a pressure test system using interrupt mode
  • You will regret not having enough books when you need them
  • TCPMP LINK Problem
